Question about Furuno Boating
No BP on Furuno 183o radar
Got a problem with a Furuno radar scanner.Display did not come up.I found a short mosfet in the modulator board(SK777)After changing the transistor,display shows no BP(bearing pulse)and I cannot enter in TX mode.I am using my own cable,so this is not the problem.No schematics
apart from the information in the user manuel.
Antenna is turning ok,but there is no magnetron current either.
electronii 389
rjrod888
  • 8 Answers
SOURCE: Furuno Radar 1623 and 1715
Hello.
According to the operating manuals of the two radars (found on Furuno's Website (www.furunousa.com), they do use the same antenna cable.
Hope this was helpful.
Posted on May 04, 2009
  • 111 Answers
SOURCE: Hi, I have a Radar Screen. Furuno 1942 MK2 . What
A 1942 is a 6 kw radar a 1720 is either a 1.5 or 2.2 kw dome. The two will not work together. Besides the cabling is different. Also the radar cable on a 1942 is round where as the 1720 is square. The 1942 display should work fine on a 1943 navnet radar.
Posted on Oct 31, 2009
SOURCE: testing and operation of furuno 1621 radar.
I have the original manuals.....
Posted on Jan 11, 2010
TechnoMarine
  • 132 Answers
SOURCE: furuno radar antenna not rotating
yes, this is a common failure after hours and hours of use
Posted on Jan 13, 2010
TechnoMarine
  • 132 Answers
SOURCE: Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Posted on Jan 16, 2010
No data at >1mile
If the unit is new and never been set up post installation, that's probably your problem. You have to go into the Installation Wizard and set the unit up properly. There are multiple choices of displays and scanner units to select to obtain the configuration you have. Then the radar has to be optimized (auto-tuned). If you don't have access to an installation manual and feel confident yourself, you'll need to contact a local Furuno authorized dealer or call Furuno USA tech support and they'll walk you through it. Their number is 360-834-9300
Dec 26, 2013 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno radar 1715
Cek wiring to scanner, change reedswice sensor /heading sensor. If the problem not solve, change the display with the new one.
Oct 01, 2013 | Furuno 1715 LCD Radar System GPS Receiver
We have a radar Furuno 1622 - the scanner scans but sometimes we got echo and targets, sometimes none, sometime we get echos and targets on a small range display (1mile) but none on 2 or 4 miles range,...
I know this question is very basic, but did you check your gain and clutter settings? That echoes show in short range, disappear, reappear, and are not consistent on long range sounds normal to me. Auto settings sometimes also can get a bit mad, then manula settings makes sense.
Did you run the unit and scanner test?
Dec 04, 2010 | Furuno 1715 LCD Radar System GPS Receiver
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
A furuno 1715 lcd radar was wired to battery backwords
internal damage to the display, fixable by Furuno, and probably economically feasible (guess $250 with round trip to Furuno)
Nov 17, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Hi, Furuno 1731 radar - no sweep/echo seen on screen. Scanner is rotating and other display is normal.
Go to longest range and full Gain min Rain and Sea Clutter
Do you have speckle? Yes = Receive OK, Wiring OK,No transmit (magnetron or modulator) No = Most likely a broken wire
There is a very tiny coax (shielded wire) that is know to lose its' center conductor, which is very delicate
Oct 18, 2009 | Furuno 1623 Radar 16nm Range
No radar target images
Sounds like your video cable inside your radar cable. Also brings your Gain back to zero, STC back to Zero and rain back to zero. Next increase your gain until you see a picture. If none of that is working, check your cable then finally call a dealer.
Oct 15, 2009 | Furuno 1715 Radar 24nm Range
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
Boating Logo
254 people viewed this question
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
David Burbee
David Burbee
Are you a Furuno Boating Expert? Answer questions, earn points and help others
