Question about Brother MFC-620CN All-In-One InkJet Printer
Printing problem Dear expert, I was in the middle of receiving a fax and half way through it stopped and has since displayed the word "Printing" on the LCD display, but nothing has come through since. I have tried to unplug the machine to reset it but when it comes online again, the work "Printing" appears again and I cannot use the machine for any function at all. I have tried to just print a copy but it won't allow me to do anything. Please help!
  • ElizabethS Oct 21, 2007
    Unfortunately it didn't work but thanks for trying. I appreciate it.
  • benthefitter May 06, 2009
    Halfway through receiving a fax, the bloody thing stopped and the lcd screen says "printing", i've tried turning it off and on etc, and tried your solution but to no avail. Do i need to throw it out of the window??????
  • Brother Master
  • 1,113 Answers
Sounds bad, possible main pcb fault, try reset by.  menu * 2864 real quick then 99 set or start.
Posted on Oct 21, 2007
2 Suggested Answers
  • 508 Answers
SOURCE: document jam, printing is fine, but won,t copy or
check for debris or paper fragments!!!!
Posted on Jun 25, 2009
I have a fax-jx200 it shows ;auto print off . so there are faxes in memery how do i get to turn off auto print.
Press [ON/OFF] to select <auto print off>
The fax starts receiving documents to the memory
To cancel press [ON/OFF] again.
Oct 20, 2011 | Canon FAX-JX200
I have a SFX-11 fax machine. When I received a fax this morning and it stopped in half way. the screen shows nothing, but the handset (phone) is ok.
Stopping in the middle of receiving a fax and the display going blank is a good indication that the circuit stopped functioning.
Try dialing out and you should hear the beeps as you press the buttons.
Or ask somebody to call you to see if it rings or not.
The rest is obvious. :)
Apr 01, 2011 | Office Equipment & Supplies
The LCD screen keep displaying "Printing" but
I have seen this so many times I thought I would post an answer on this so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
Good Luck and Thank You for using Fixya!
WheatlandServices
Dec 16, 2010 | Brother MFC-8220 Fax
Hello! How to program automatic reception of a fax after 4 calls (at the weekends, when at office anybody isn't present. Thank you. Best regards, Veronika
hi; Receiving Both Documents and Telephone Calls Automatically: Fax/Tel Mode If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings: ??? Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting). ??? Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting). ??? Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting). 1 Press [Menu]. 2 Use [{] or [}] to select <DATA REGSTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>. 3 Use [{] or [}] to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>. 4 Use [{] or [}] to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>. 5 Press [Start/Copy]. 6 Use the numeric buttons, or [{] or [}] to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. 7 Use the numeric buttons, or [{] or [}] to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>. Note ??? If paper jams, see "Troubleshooting" on page 53. ??? If the Ink Lamp lights up faxes will be received to memory. 8SEC. 22SEC. Use [{] or [}] to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6. 9 Press [Stop]. Setting ends and the fax returns to standby mode.
Oct 14, 2010 | Canon FAX-JX200
Hi. i hope you can give a suggestion with our brother intellifax 2820. Whenever printing a received fax, the machine prints out a blank page in between each received page. so, for example, we receive pg1,...
press "menu/set, 1, then 3. you should see "paper size" on display. select "letter" if thats what you are using, and press "menu/set" again, then "stop/exit" to back out. next, make sure your "fax" button below display is green, then press "menu/set, 2, 1, then 5.using your arrow keys, select "on". press "menu/set" then "stop/exit". that should do it.
hth,
razors
Mar 15, 2010 | Brother IntelliFax-2820 Laser Fax
HP 1010 fax - only receives first pages of a fax
Do you have DSL, or any other type of digital phone line.
Usually this is caused by a "noisy" phone line; some sort of interference.
Sep 23, 2008 | HP 1010 Plain Paper Inkjet Fax
"line in use" lcd display
here is link
http://slayo.com/resetting-error-e27-waste-ink-absorber-full-canon-pixma-mp150mp160.html
you will need to do no3
EEPROM reset
Just follow instructions!
Checked by me and its working
Marko - SERBIA
Sep 11, 2008 | Canon FAX-JX200
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Received fax's are not printing. Unit prints confermations and is working as a printer but recieved fax's just park in memory and will not print.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
Jul 28, 2006 | Samsung SF-560 Plain Paper Laser Fax
Brother MFC-620CN All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
