Question about Microsoft Windows Vista Ultimate Edition
Unable to enable ntfs compression
I am unable to enable compression in my windows vista ultimate x64when i tried to its saying ''compression is currently disabled for this volume''i tried the regedit method and modified the key ''ntfsdisabled compression to 0''but still its not working its getting automatically reset to ''1''i am running only 90mb free space in cpls help me with this problem
  • 14 more comments
  • playboycenso May 26, 2009
    yeh . "c drive"
    yeh sys restore is enabled in all drives but currently my c drive dont have any restore points
    HKLMSoftwareMicrosoftWindowsCurrentVersionExplorerVolumeCachesCompress Old Files does not exist
    till volume caches its ok it exist but, compress old file does not exist
    pls tel me a way to enable compression
    when typed compact in the comand prmt, it says like this
    Microsoft Windows [Version 6.0.6000]
    Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    C:\Users\SeDaTeD sAdIsM>compact
    Listing C:\Users\SeDaTeD sAdIsM\
    New files added to this directory will not be compressed.
    0 : 0 = 1.0 to 1 Contacts
    0 : 0 = 1.0 to 1 Desktop
    0 : 0 = 1.0 to 1 Documents
    0 : 0 = 1.0 to 1 Downloads
    0 : 0 = 1.0 to 1 Favorites
    0 : 0 = 1.0 to 1 Links
    0 : 0 = 1.0 to 1 Music
    1150976 : 1150976 = 1.0 to 1 NTUSER.DAT
    1310720 : 1310720 = 1.0 to 1 NTUSER.DAT.bak
    0 : 0 = 1.0 to 1 Pictures
    0 : 0 = 1.0 to 1 Saved Games
    0 : 0 = 1.0 to 1 Searches
    0 : 0 = 1.0 to 1 Videos
    Of 62 files within 1 directories
    0 are compressed and 62 are not compressed.
    15,437,844 total bytes of data are stored in 15,437,844 bytes.
    The compression ratio is 1.0 to 1.
    i tried stopped cleared all the restore points stopped the hardware monitoring but still the very same old condition..pls help
  • playboycenso May 28, 2009
    hey ws runin n xp pro n rcntly upgrded 2 vista
    drv is ntfs.. but i wnt to compress some of my folders. i am not able to do so when i tried to..its sayn compression is currently disabled for the drive
    wat to do???
    by doin so wer wl it gt stored???
    lme giv a try n c wat hpns wthr it wil wrk r not
    hey but v cnt do it 4 installed application folders n directories n all r8
    i wnt to do it for installed aplication folders too
    dats wat i was sayin bt..
    ders a way to do so by clickin on the drv properties amd den chckin the box " compress drive to save disk space" but by doin so
    its sayin compression is currently disabled for this volume
    and even i tried all d wayz mentioned in my prvs posts/threads
    wat2 do nw????
  • playboycenso May 30, 2009
    THNX A LOT U PPL DIN SLV IT..ANYWYS THNX FOR ALL DOSE SUGGESTIONS
    hey i din mean it in ny negtv sense..i finshd 2 un install some applications and even cleared the temperory files etc.. right now my free space is 1gb bt why is dat i cant compress nw and even other drives.
    mine is 80gb drive and i have partioned it into 4 drives. on all 4 drives is the same problem and except c drive(1gb free spce) other drives are having 8-9gb free space and above y is then i cant compress those drives
    if u can help me with this the pls do..
    i am sory if i sd anything due to my lack of knoowledge..pls take it in that sense
    pls.. 1nc again sorry
    and 1mre thing in regisry
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem]
    "NtfsDisableCompression" its value is set to 1
    when i changed it to 0 and restarted my computer its value is automatically changing to 1 again
    i guess this is the reason behind the prb. if the value is 0 means i gues i'l b able to compress but y its automatically changing..
    any way to prevent it
    hey thnx lol for the help what i did was i manually deleted the registry
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\FileSystem] "NtfsDisableCompression"
    and created a new 1 with the same name and set the binary value to 0 and restarted the computer and now its working.
    thnx man the prob is solved now
  • Greg Margossian
    Greg Margossian May 11, 2010
    Is System Restore currently enabled?
  • fougzki May 11, 2010
    Is that on the harddrive files compression? Just asking
    Novelist:
  • 79 Answers
There are a number of reasons for compression to be disabled, but check these two things:
The cluster size for that volume:
Compression is not supported on cluster sizes greater than 4KB
By default NTFS cluster size for Windows Server 2003 never exceeds 4KB
This one is less suspect, but another registry entry that MUST exist
for 'Disk Cleanup' compression to take place:
Other thoughts:
The command line "compact" utility can be used to disable compression for a folder and, optionally, it's subs. This might be a suspect if it were invoked at any time on that volume.
PLEASE READ:
Before you invoke compression on a volume it's best to read this "Best Practices" article: http://support.microsoft.com/kb/251186/EN-US/. Compression can have a detrimental effect on performance if used improperly.
Posted on May 26, 2009
  • jcoady
    jcoady May 26, 2009
    Friggin backslashes didn't pass thru. Let's try this:
    (Second comment re: registry entry)
    "HKLM\\Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\VolumeCaches\\Compress Old Files"
  • jcoady
    jcoady May 26, 2009
    FYI - Cluster size is included in your chkdsk statistics.
    i.e.: 512 bytes in each allocation unit.
  • 1,959 Answers
Since you have no restore points, I'd remove monitoring on the drive you wish to compress and then try the hard drive compression. Since its currently being monitored, this may be why you can't compress the drive. You can choose to monitor all or some hard drives as part of system restore. Hope this gets you going. Good luck.
Greg
  • 5 more comments
  • Greg Margossian
    Greg Margossian May 28, 2009
    Assuming Vista came with your machine, or you already had XP installed when you upgraded, NTSF must already be the format of the hard drive therefore, preventing you from compressing a drive that's already been compressed.
  • Greg Margossian
    You compress individual folders by right clicking on the folders themselves and select "Send To" and then select "Compressed Folder". Forgive my confusion earler, I thought you were trying to convert from FAT32 to NTSF.
    Greg
  • Greg Margossian
    It will be stored in the same directory the source file is stored i.e. if folder is in "My Documents" the "zip" file will also be stored in "My Documents". it will have the same name, only it will have a 'zipper' on the folder and be in the format .zip
  • Greg Margossian
    If you're talking about the folders inside your Program Files folder, you can't run most applications from a zip file or compressed folder.
  • Greg Margossian
    If you only have 90MB free space, unload all unecessary files. Prior to trying to compress the drive, there's a disk cleanup option. There must be files either in Recycle bin waiting to be deleted or temp files to be deleted. Disk Cleanup will show how much space can be saved by deleting these files. To do a Hard Drive compression, there needs to be sufficient free space on your Hard Drive to perform the compression. After running Disk Cleanup if you still have only 90MB of free space, either get a flash drive to move some files over or back up files onto a CD or DVD prior to deleting them from your Hard Drive. Hope this answers your post.
    Greg
  • Greg Margossian
    Greg Margossian May 30, 2009
    Given the time and effort spent on your problem and the final solution provided did identify and provide a solution, a rating would be greatly appreciated. Thanks very much and Good Luck.
    Greg
  • Greg Margossian
    Taught you how to compress files, couldn't compress all you wanted due to lack of free space on hard drive (no fault of mine) and I get "Thanks for trying"?
Administrator password Dell Inspiron 1720
If the system is asking for an administrator password in Windows and you are wanting to format and reinstall the system, then the password shouldn't be an issue. Most inspiron systems are equipped with a PC Restore partition CTRL+F11 just after the Dell Splash Screen should enable the restore process. If PC Restore doesn't work, then boot to the XP CD and format the NTFS partition and install Windows XP clean. If you have Windows Vista, the PC Restore is run from the F8 Boot menu. If no restore partition is accessible in Vista, then again Boot to the Vista DVD and format the NTFS partition and install VIsta.
Sep 30, 2009 | Computers & Internet
How do i enable ntfs compression in vista x64
You don't want to compress your drive... it's really not recommended. And you can't de-compress it once compressed.
I will suggest buying a new drive; Harddrives are rather cheap, and cloning utilities will make the transfer of your data eazy peazy.
May 26, 2009 | Microsoft Windows Vista Ultimate Edition
Unable to enable ntfs compression in vista (hard disk-"all drives
Compress an entire NTFS volume
warning.png You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
bullet.png Double click on My Computer on the desktop.
bullet.png Right-click the volume you want to compress, and then click Properties.
bullet.png In the General tab, click to select the Compress Volume to save disk space check box, and then click OK.
bullet.png In “Confirm Attribute Changes”, click the option you want.
You may have already attempted this but Maybe not....
This error usually happens in Linux but occasionally within windows.
My apologies if this does not help.
I am unable to enable compability mode in vista by using admin ac
Right click on the file you want to use, goto properties then compatibility.
Then check the box that says run this program in compatibility mode for....then choose what operating system you want.
Feb 19, 2009 | Microsoft Windows Vista Home Premium with...
Enabling java scrpt in browser
Follow these steps:
  1. Open your browser (I.E. 7.0)
  2. Click on Tools button (it is located in the upper right part of the screen)
  3. Select Internet Options.
  4. Click on Security tab.
  5. Click on Custom Level.
  6. Scroll down until you see section labeled Active Scripting.
  7. Select Enable.
  8. Click OK to save changes.
  9. Confirm Yes and click OK.
  10. Close and restart the browser.
Jan 30, 2009 | Microsoft Windows Vista Ultimate Edition
Playing games
The software company that wrote the game does not support Vista. Check back with them often to see if they will in the future.
Nov 03, 2008 | Microsoft Windows Vista Ultimate Edition
Dvd rom icon missing vista ultimate
reinstall the vista
or try to install a software named'Alcohol120%'
Oct 30, 2008 | Microsoft Windows Vista Ultimate Edition
Connectivity - Network Printer
I am having windows vista home basic in my computer. I am not able to share files to other computers connected in my network. also, I am unable to view network computers in my network. How to enable network computers visible.
Aug 03, 2008 | Microsoft Windows Vista Ultimate Edition
UNABLE TO UPGRADE TO VISTA ULTIMATE
hi,
what is the error..can you explain bit clearly
Jul 17, 2008 | Microsoft Windows Vista Ultimate Upgrade...
Unable boot vista ultimate (installed earlier) after installing new xps2
You have to reinstall vista bootloader.
Just insert vista dvd in the drive and boot from it.
Select startup repair and it will fix everything back to normal.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
922 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
