Question about Whirlpool Dryers
No heat at all, every thing else appears to be ok,checked heater element with meter and has a circuit
  • 89 Answers
It would be the thermostat most likely.
in the rear there should be one or 2 sensors onthe element
the circut should be complete.
but first make sure the power in the house is good..
if one side of the 240v is out, it could run with no heat
test each straight prong with the middle L type prong,each should show 120v and then the 2 straight ones togeather should give 240v or around.
if either one is out its a matter of flipping a breaker or putting in a new fuse. then figuring out why it blew
Posted on May 26, 2009
My lg convection oven works fine in microwaveode but in convection mode things don't get baked properly...what could b the problem? Pls help
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
May 18, 2015 | LG Ovens
My samsung flat top electric oven or broiler want work and it's reading error code E-08
E08 is a oven heating error which basically means there is either a problem with the heater or the oven sensor. In this case i would check the oven sensor with an ohms meter. should read around 1080 ohms at room temp. Also try unplugging the unit for 30 seconds.
Apr 14, 2015 | Samsung Ovens
No elements working on kenmore range
THINGS TO CHECK:
the broil element
The bake element
Apr 17, 2014 | Frigidaire Ovens
Oven not getting hot
THINGS TO CHECK:
the broil element
The bake element
Apr 06, 2014 | Frigidaire Ovens
Oven element
The bake element
THINGS TO CHECK:
the broil element
Feb 15, 2014 | Frigidaire Ovens
Oven won't heat up, display flashes bake
THINGS TO CHECK:
the broil element
The bake element
Feb 12, 2014 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire fef336fmc
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
The bake element
Feb 10, 2014 | Frigidaire Ovens
The circuit breaker continues to blow off. I believe this occurs when the heating element is activated. I have replaced the heating element. The problem persists. The isolator bushings seemed to be OK....
Hi.SHORT CIRCUIT MIGHT HAPPEN I THE HEATER.IC'S MIGHT HAVE BEEN DAMAGE.or short circuited.you may try to check it using a multitetster.Set it to ohms .and check continuity of the circuit.If pointer goes rapidly more than its maximum then there is short circuit in the heater.hope this helps..
Jun 18, 2011 | Kenmore Microwave Ovens
The bottom heating element is only getting 110 volts. When checked with meter it shows a complete circuit. But the meter slowly decreases in the circuit check.
There is 110V on the lower element at all times.
That's because water heater thermostats only turn off 1 leg of the 220V circuit.
If upper-or-lower thermostat is bad, one thing that happens is the lower element reads 110V all the time and never tests for 240.
To solve the problem, replace both thermostats.
Or test the thermostats to see which one is bad.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Oct 28, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Seat heaters not working .Checked all fuses. All OK
Both seats? Possible open circuit in 1 of the heated seat element. Try measuring resistance with a multimeter.
Check for ohms. If O.L is present on a meter, you must
replace the heater element.
Nov 30, 2009 | 1999 GMC Jimmy
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
