Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Wl-520 gc please help me i have adsl connection (pppoe), just bought a wireless router a few days ago still cant install it
  • Taswombat Nov 20, 2007
    I have a nb 1300 adsl modem/router,
    I am trying to use a ASUS WL-520gc as A network hub and wireless access point.
    but I am unable to configure it to allow internet access ????
    my Belkin Wireless G router does this job perfectly!!!, but does not have the abillity to use the 15db external aerial that I have.
    as advice greatly appreciated
    President:
  • 2,961 Answers
You must need to put in more than the ppoe connection type, there is the vpi =0, vci =38, then input your isp's username and password to get a connection.
All this must be done via the RJ45 cable and making sure that the pc's lan card is set to obtain an ip address automatically.
To get into the routers settings, type into your web browser either 192.168.0.1 or 192.168.0.100, as i'm not sure that actuall routers address, sometims it's on the underneath or refer to the manual.
Posted on Oct 21, 2007
Try 192.168.1.1
Posted on Nov 30, 2007
SOURCE:
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
Nov 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Modem and Router connected but cannot access internet.
ADSL Modem's LAN -> connect to your Router's Brodband port through ethernet cable.
or
connected through bridging or POP
Apr 02, 2010 | Computers & Internet
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Cannot connect to internet
Make the Ip address similary to the router, example 192.168.1.25 should work.
SUbnet mask will then fill in automaticaly, just leave it
then Default gateway will be the routers IP. 192.168.1.1
the dns server would be the ip of your internet provider. I would leave it blank at first, see if it will work then. If not, then ask your service provider for it. If they give u a number, then you will have to go into the router properties, and change the dns and stuff like that in there aswell.
good luck
Dec 25, 2008 | Computers & Internet
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
3com wl-542
have you tried to Use PPoA?
Dec 10, 2007 | 3Com OfficeConnect Router
ASUS WL-520g wireless router and hutchison broadband connection problem
You need to contact your ISP if the internet connection is not there....
Nov 06, 2007 | ASUS WL-500g Wireless Router (WL500GDLX)
WL 520 GC can only acess net in "default" before encrypting
To enable WEP encryption requires configuration changes in two places the router (WL-520G) and for the network adapter on the associated with the computer expecting to use the wireless router. Do you both believe you made the appropriate changes to both devices required? The router and the computer
Another possible issue is either the router or the network adapter do not support WEP meaning the option is not possible at all.
Oct 24, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
670 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
