Question about Manitowoc MAN-KF2 Koolaire Freezer Reach In Two Section Self Contained 6in Legs
Freezer not keeping food frozen and their is ice on the liquid line filter.
Their is ice on pipes leading to liquid line filter and freezer not keeping food frozen.
    President:
  • 1,902 Answers
This is one of two things, either the inline filter on the machine has gone bad. Or there is a leak and it is low on freon. If it is low on freon a company can come out and put in a saddle tap and check both freon levels and also add some dye for leak check.
Posted on May 26, 2009
How do I defrost the water line to ice maker on a Kenmore Coldspot model 5151200
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 24, 2015 | Kenmore Refrigerators
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
Oct 12, 2013 | Refrigerators
Will not dispence water
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WATER WILL NOT FLOW
Oct 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Replaced the water filter 3 days ago, no water now. Took filter off and it had so much pressure it almost blew out of my hand. Put old filter back on and same problem. Ice maker works fine.
the frig uses a dual valve and the foutain water is filter water the water line is frozen ( i think ) and if you warm up the freezer it will flow . try it and we'll go from there .. freezer tempt should be around 0 to 5 deg . also ck the water blater behind the crisper and see if its frozen and veg will also freeze . this may be caused by a bad dampner control between the freezer and the fresh food side. mm hope this helps . feed backk pls ..
Nov 08, 2010 | Hotpoint HSS25GFP Side by Side...
I have a Kenmore upright freezer and had it checked. The problem was that it want keep food frozen. The repairman put freon in it and said that was the problem. So put cup of water in there overnight and...
If this is a frost free freezer,the evaporator coils could be frozen over with ice,due to a bad defrost system part.
The freezer fan motor may not be working.
There could be a refrigerant restriction in the lines.
The compressor could be bad.
The refrigerant leak could be large and the refrigerant leaks out quickly.
Sep 19, 2010 | Frigidaire Freezers
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
My bottom freezer is making ice but not keeping the food frozen
The flow tubes are blocked.You will need to defrost the unit,unplug and pull off as much ice as possible.You can put pans of hot water in the freezer.
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Freezer Does Not Stay Frozen
one of the hardest things to diagnous is food defrosting in the freezer. i found out the hard way about 35 years ago, but not until i banged my head against the wall a few times. the problem was the customer didn't have enough food in the freezer as she was a weekender.frozen food needs frozen food to keep the food frozen confused? so was i . every time your refrigerator goes into defrost( usually every 8 hours) a heating coil comes on in the back of the freezer. if the freezer is not full enough this heater can raise the temperature in the freezer to 40 degrees which will soften the food and melt the ice considering the time it takesto refreeze the food. i never forgot that service in fact i can see it in my head right now.. try this cure first let me know
Feb 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting water from dispenser in door
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Manitowoc MAN-KF2 Koolaire Freezer Reach In Two Section Self Contained 6in Legs Logo
314 people viewed this question
Top Manitowoc Refrigerators Experts
Tim Whalen
billconfused
Are you a Manitowoc Refrigerator Expert? Answer questions, earn points and help others
