Question about Lexmark Z645 InkJet Photo Printer
I can not get my disk to load on our new computer, and when i try to do it manually it shows that it is installed but it still will not work.
The disk will not load at all, and then when i do it manually , the printer still will not work.
  • Roopesh S
    Roopesh S May 11, 2010
    Please let us know the name and version of the operating system (Windows XP / 2K / NT, Windows Vista, Mac) that you are using on your computer. This information is important for us to troubleshoot the issue further.
  • Lexmark Master
  • 684 Answers
To access the Lexmark Z645 XP driver, you may copy and paste the web address given below:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:548:0:0&emeaframe=&fileID=8606&searchLang=en&searchLang=en
Please use the following steps to download the Lexmark Z645 XP driver to your desktop:
1. Select "Window XP" from the drop down list
2. Click on "Download Now."
3. On the "File Download" screen, choose "Save."
4. The next screen will be titled "Save As." Choose to "Save in Desktop" and click "OK."
5. You should see files being transferred.
****Note**** If your browser uses a different file downloading format than specified above, you will need to resort to your browsers help files for downloading instructions. The object of steps 1 - 4 is to download the driver to your desktop. This way it is easily accessible.
6. Once the files have completed downloading, double click on the icon with your file name.   7. On the "Win Zip Self-Extractor" screen click "OK." To unzip the downloaded file choose "Unzip."
8. A screen will then display the number of files unzipped successfully, click "OK."
9. Please follow the on screen instructions to complete installation of your Lexmark printer.
Posted on May 27, 2009
Having issues with Acer Aspire 5810TZ-4238, Computer saying NTLDR is missing, Press Ctrl + Alt + Del to restart, I did this two or three times it did not work. I took my three restoration Disks out and...
If you are recovering to a new harddrive, because your original HD crashed or is about to crash or can't boot, then find a tool (GPartEd is free and works) to format the entire disk to an NTFS partition. If you want to split the partition to OS and "other", Windows 7 Home premium 64-bit needs at least 100Gb. Basically: PRE-PARTITION before trying to restore to a new HD. To me, these other answers are misleading.
Dec 19, 2010 | Acer Aspire 7110-2069 Notebook
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
My built-in dvd will not work.
hello,
The most common reason for the system not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your system including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your system going again!
Hope this will help....
May 30, 2010 | Polaroid TDX-01930B 19 in. LCD HDTV
When i install window xp in my laptop it shows a blue screen.
First when you power up the computer PressF1 or F2 or "del" key to enter in bios .
Then load optimal defaults then save settings and exit.
Then boot your computer with winxp disk..
Delete all partition of harddisk and create partition again .
Try this 2-4 times you done it.
If still face problem then you have to refix RAM memory. Also check that your winxp disk is working fine.Change your winxp disk then try.
Let me know if you need more assistanse.
Thanks.
Sep 01, 2009 | Computers & Internet
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
I couldn't install windows xp in Compaq cq45 112au
Try using an win 98 startup disk on floppy and start your computer with disk in.Let it finish loading the drivers and then type in fdisk erase your partition and then make a new one. then restart the computer with floppy still in then this time type in format c:/ and format the drive after it is done then you can install win xp.But you need to repartition your hard drive and then format after that to get xp to install Oh yeah when you go to fdisk allow large drive usage
Jan 25, 2009 | Computers & Internet
Not loading when i turn the computer on
Start the computer from the installation CD, choose Disk Utility from the menu, and then choose Repair Disk with the internal HD selected. If that doesn't work, you can try a new OS installation. If your data is important, don't erase the drive during installation and select "Archive and Install" -- if your data is *NOT* important, you can just repartition the drive and install the OS.
Jul 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Loading disk
ill sugest u to talk to manu tech cause they can tsake access of ur computer and can pin point cause... a lots t/s needs to be done in this case
May 13, 2008 | Microsoft Windows Vista Ultimate Edition
RCA M202E
the driver is actually either on the disk that came with it or it should pre install it off of the device itself.
my suggestion try finding the disk to install it
Oct 03, 2007 | RCA M2000 MP3 Player
Lexmark Z645 InkJet Photo Printer Logo
184 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
