I have two HP 4355 OFFICEJET ALL-IN-ONE and one of them recently behaving rediculous , as it stop printing with the message INK-CARTRIDGE EMPTY , instantly when the same cartridge works fine in the other machine. Please help me . Thanks.
When the print
cartridge contacts are dirty and the printer cannot detect/communicate with
print cartridge.
Clean the contact points on the cartridges with a
dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the
cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from
the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new
cartridge .
Hope this help. Please
Rate My Response! Thanks!
PREM
Problems with Hewlett Packard Officejet 4355 printing can often be due to issues with the cartridges. The printer has two cartridges, one black and white, and one color. Both can be physically inspected for problems. The printer also has a self-test report to determine if there is a non-obvious problem with the cartridge. The report can provide valuable information, including status.
Take the black ink cartridge out of the slot on the right. Be careful not to touch the ink nozzles or the copper contacts.
Look at the cartridge and make sure that the plastic shipping tape isn't still attached. There shouldn't be any tape covering the ink nozzles.
Replace the black cartridge and then perform Steps 1 and 2 on the color cartridge. The color cartridge is the one on the left side.
Print a self-test report. Load paper in the tray and press "Setup." Press "2" and then "4." The HP Officejet 4355 will print a report. Make sure the lines of color extend across the page. Missing, faded or streaky lines can indicate a cartridge failure. If the color bars don't show as black, cyan, magenta and yellow, you should clean the cartridges.
Press "Setup" and then press "6" and then "1." The print cycle will commence. Allow it to complete and then print another test report. If the test still shows errors, replace the cartridges.
