Question about RTO PasLode 900420 Impulse Framing Nailer
I cant get the head of my framing nailer back together
I took my framing nailer all the way apart and now i cant get the head back together which holds everything in the housing please help
  • David Ford
    David Ford May 11, 2010
    what model number we talking about.
    Sniper:
  • 79 Answers
Go to Paslode website and get the parts breakdown/schematic. Making sure that everything is right way. This problem is a tad tricky. Trick is don't get mad or discouraged. The gun will win. Lemme know if you need anymore help. Pleas rate me.
Posted on Jun 18, 2009
Nails were loaded backwards in my Hitachi nail gun. I can't unload them
Sorry to hear, but it happens.....
You'll have to take the magazine apart and disassemble at least as far as the nail got. I'm giving you the webpage from toolpartsdirect.com for the schematic diagram and parts list to help you take everything apart, and of course, put back together again. http://d3cmirsdb60x3h.cloudfront.net/schematics/hitachi/nv83a2.big.pdf
Be sure to check all parts for damage, such as scarring on metal parts that might cause nails to stick later.
This site is a good place to get parts. Very fast delivery!
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Apr 24, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Hitachi roofing nailer leaks air out the back after falling off roof, I have 5 of them all with the same problem. any ideas?
SOLVED! I replaced all the o rings put it together and air jus blew out the exhaust port. I made the mistake of pushing Piston plunger cylinder into the gun till it seated. this left a gap between the head and cylinder. I took the gun apart, removed the cylinder, an reinstalled it only far enough to seat past the o ring gasket. I then installed the head and let the head seat the cylinder as I tightened the screws. this worked on two guns with the same problem. Jn 3:17
Dec 11, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
The shaft or pin that drives the nail does not retract on my mastercraft 3 1/2 framing nailer. #58-8434-4
take the back cap off of the nailer. There is another loose cap in that head, most times that gets stuck. Believe me, I was raised by a carpenter that had nail guns before anybody else did. Also, sometimes that plunger gets bent, just straighten it out. Check for blown o rings. If it is old, take the trigger assembly out and clean it out. Be sure to oil everything well before you put together. We use marvel mystery oil, or nail gun oil.
Jul 08, 2010 | Air Tools & Compressors
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
I TOOK IT APART & CAN'T GET IT BACK TOGEATHER
it goes under the side where the follower is, you will need to remove the cover on that side and pull back the follower, you will see the slot where it rides, also there was a spring that pushes it out of the way. I suggest going to Paslode.com for a parts breakdown. Let me know if I can help further.
Jan 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
It is a nr83a2 model. I have taken it apart and cant get it back together
No problem, go to Hitachipowertools.com and type in your model number and towards the bottom of the list when you see the nailer click on it and you can get a parts explosion to reassemble. Remember to lightly grease the o rings upon assembly. Let me know if you still need help. If I have helped you with your request would you please rate this response accordingly and thank you.
Oct 03, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Took it apart and cant get it back together
if this a Hitachi go to Hitachipowertools.com and type in your model number and you can download a breakdown for it. Let me know if you still need help
Oct 03, 2009 | Hitachi Tools & Hardware - Others
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
Need manal
Yes there is, go to Paslode.com and on the left side of the site is an area where you can enter your information to get the manual and breakdown. If you still need help let me know, I have been factory trained on the Paslode tools.
Jan 29, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
119 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
