Question about ViewSonic VX910 19" LCD Monitor
Intermitant "snow" and incorrect hues
Problem is random. occurs at power up, and usually does not return after a reboot of system. It did it on two different computers, so it is hard to suspect drivers (also because no regularity). But it can go days without occurring, so hard to suspect monitor. Ideas?
  • 822 Answers
Check your vga cable. and your resolutions.
Posted on May 26, 2009
Model LNT4061FX/XAA Intermittent snow then picture. Is there a cure?
Intermitant snow means your tv is not getting signal continuously. Please check the input signal connection and source to your tv.
Dec 26, 2013 | Samsung LN-S4041D 40 in. LCD HDTV
2007 rsv1000r, bike will randomly cut in/out at the 5500 rpm mark and rev no higher as if a fault has occurred but nothing comes up on dash. has had new reg/rec, several sensors inc intake pressure and...
Hi, Aaron and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition and leaking.
3. Spark plug gap too close or too wide.
4. Faulty ignition coil, module, and or sensor.
5. Battery nearly discharged.
6. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
7. Intake air leak.
8. Water, dirt, or rust in the fuel system, carburetor and/or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose, dirty, or corroded ignition module connector at crankcase.
13. Faulty MAP, CKP, O2, and/or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damaged intake or exhaust valve.
For low rev's the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question please visit the website below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/2007+aprilia+rsv+mille+1000r
Aug 31, 2013 | Aprilia RSV Mille Motorcycles
Intermitant fireing and the hammer doesnt return to pick up the next nail
If the hammer isn't returning, that is usually a sign of needing oil. Also, new guns that aren't broken in yet can do that as well, but oil usually helps them too.
Oct 22, 2009 | Hitachi NR90GC 3 1/2" Gas Powered Clipped...
LED on abit ST6
every motherboard should have a led light always on to indicate that there if power in it. the problem with system rebooting has to do with the ram or processor, since you said it does not recognize the hdd at times that means that the ram is working abnormally i.e it is week, u know ram means random access memory, so change the ram and make sure u get the right ram for your system
Jul 11, 2009 | Abit ST6 Motherboard
Random rebooting when connected to our wireless account
Possibly what you thought was a virus was actually early signs of this very instability. Back up everything you care about on that machine at once! Then run diagnostics (google some good download sites and do the downloads to a floppy or CD on the other machine). You are probably looking at buying a replacement (few eMachines are worth repairing)
Apr 25, 2009 | E-Machines eMachines Desktop PC
Locked and cant get in
try the last 4 digits or ur number orr! 0000
Apr 14, 2009 | Samsung Hue (SCH-r500) Cellular Phone
How to take digital photos of snow
you need to edit the photo with an editor to adjust hue. in the past film camers used lens filters to filter out the blue tint.
Dec 07, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Problems with dell 4600
Try to open it in safe mode. If it opens and don't reboot then right click on my computer->click on properties->click on Advanced Tab->setup and recovery framework click on settings->in system failure framework remove checked from Automatically restart.
Oct 23, 2007 | Dell Dimension 4600 PC Desktop
ViewSonic VX910 19" LCD Monitor Logo
62 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
