Question about Sharp 27H-S60 TV
Sharp 27G-S60 TV analog or digital?
Is this television have an analog or digital tuner? I tried looking at the manual, and also looking at the Sharp site, and I am not able to determine if this set is ready for the digital transition. Thanks, V. McClellan
  • lghadle Dec 29, 2007
    27H-S60 television manufactured March 1996. Same question. Is this television able to receive digital broadcast?
    Genius:
  • 1,694 Answers
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Posted on Nov 20, 2007
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: http://www.crutchfield.com/S-4LS7pNsldXK/p_70037G4U/Sharp-LC-37G4U.html . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: http://pdf.crutchfieldonline.com/ImageBank/v20040615154800/Manuals/700/70032G4U.PDF .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
Is this a digital or analog tv?
http://www.cnet.com/products/sharp-u-s60/ ANALOG looks like as it is a crt .not LCD
Jul 03, 2015 | Sharp 32U-S60 32" TV
32 inch sharp aquos can't find any channels with rca amplified indoor antenna
That could be because the antenna is pointing in the wrong direction, or it's just not getting enough signal where it is in your home.
Have a look at neighbours antennae. See the direction they are pointing. Point yours in the same direction too.
Other causes: you are trying to tune the analog tuner rather than the digital tuner.
Sep 07, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My sharp tv will not switch from analog to digital
When you set up your tuner, select analog + digital then do a channel search.
May 28, 2014 | Sharp LC46SB54U 46 in. LCD TV
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Mar 09, 2011 | Sharp LC-20SH4U 20 in. EDTV-Ready LCD...
Does my sharp tv model 25k-m180 have a digital tuner
No,all regular tube tvs are analog tv.Must have a converter box hook up to get a free over the air DTV,or must have pay tv services like Cables,Satalite,or Telicoms signals they convert DTV back to analog signal for ur tube tv.
Apr 27, 2010 | Sharp 25K-M180 25" TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Only a horizontal line can I see in my TV
In most cases the vertical output IC and possibly a fusible resistor off of the high voltage transformer are bad. The vertical output IC is located on a heat sink and usually right next to the vertical yoke winding connectors that are green and yellow in most sets. Please take a moment to rate my answer..Thanks...
Nov 24, 2009 | Sharp 27G-S60 TV
Sharp 27G-S60 no vertical picture
your problem is due to vertical section failure.
 as you say it was intermittent for a while, but now is permanent
please check the followings as given
  • remember you should keep brightness as low as possible to avoid crt burn.
  • there might be loose contact in print or connector loose for deflection coil.
  • check supply to vertical output section
  • check components in vertical output section like electrolytic capacitors & low value resistirs.
  • check verical outout ic .
  • hope this will help
  • good luck.
Oct 13, 2007 | Sharp 27G-S60 TV
Televison & Video Logo
730 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
