Question about Acer Aspire 5520-5156 Laptop
Acer Aspire 5920 alt f10 to use my recovery dsk mismatch d2d32
I also get the D2D32 Type mismatch error when I try to recover to factory settings. When trying to create recovery discs (even though it might change nothing) I get an error message saying not enough space in D:
Acer thinks I might solve it by turning C: into FAT32, which I could convert back to NTFS after the recovery, but I have not tried it cause then I might be without a working computer
- There is one hidden 10GB partion, one 70GB system partion C: and another 70GB partion D:
My D: partion is encrypted.
A few months ago, I tried to install XP, but due to the lack of drivers I gave up. But that installation messed with my boot section making it impossible to recover Vista. After using a partion table editor I successfully managed to install Vista. Have done nothing such since.
  • 3 more comments
  • sinedubio May 26, 2009
    Hi
    I dont really create a partion. I recover by totally replacing the content on my C drive
    I choose recover system in the Acer recovery management, the system reboots, I type in password (which is correct, I tried once to type in a false password and got another error messeage).
    Directly after this I get a dialog saying Type mismatch with a heading saying D2D32
    Thx
    PowerQuest Partition Table Editor says:
    1, type 12, boot 00, cyl 0, head 1, sector 1
    2, type 07, boot 80, cyl 1023, head 254, sector 63
    3, type 07, boot 00, cyl 1023, head 254, sector 63
    No discs came with the computer and creating ones dont work as stated above.
    I can change any number using PowerQuest Partition Table Editor. I did this after the XP installation (changed to type 12 on first partition.)
    Thx
    My next step will be to backup my D drive, decrypt it, burn the recovery discs with no error messages, and make a fresh installation using these discs. It may work and it is the only way I can think of to use a legit version of Vista on this machine. I fought long and hard to get XP to work, but Acer wouldnt provide with proper drivers and the ones I found crashed on me continously
    Thank you for your time!
    No, did not really help. There is no easy solution I guess.
  • 3,230 Answers
Tell me when you get this error, after when you create partion or before?
It seems that there must be some problem in the partion table.
Post back for more help
Thanks
Posted on May 26, 2009
  • 2 more comments
  • Mukesh Kumar May 26, 2009
    Ok..
    At now you need a windows cd to install it again.
    or use the cd comes with this system (recovery Disk), and install tham from starting.
    Now just one way left, save all data to another computer HDD and reformat the whole HDD by using Fdisk command.
    Ok..
    just install a fresh copy of any OS you want and make partion at that time.
    after that you can easyly create a recovery disc.
    I recommend a software to make a recovery disk -
    Acronis True Image
    this software is very easy to use and help you to create a recovery disk of whole installed operating system.
    Good Luck
    Yes, thats also better
    Thanks
    regard
    all-guru
I did a windows update and now my aspire 5920 wont start. have tried in safe mode with and without internet but still nothing happens. i don't have a recovery disc can anybody help?
Turn on your laptop n try pressing Alt-F10....n try restart it....generally acer laptops work properly after pressing Alt F10.....
Also if u r able to turn on ur laptopn in safe mode then try deactivate windows update...and restart ur laptop in normal mode.....
Mar 13, 2010 | Acer Aspire 5920-6727 Notebook
My Acer Aspire 5920 won't fully recover
is hardware problem send to repair or a new one
Dec 29, 2009 | Acer Aspire 5920-6335 Laptop
Laptop does not boot up and recovery from cd gives d2d32 type mismatch error
A couple of things to try in the bios:
1. try changing the SATA mode to IDE for the restore and then back to AHCI mode after it was complete
2. Enable disk to disk recovery mode: To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility,
then select Main from the categories listed at the top of the screen. Find D2D
Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this
value to Enabled.
Jul 11, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 5920 problem
Your best play is to restore the machine to the factory settings. To do this, power up the machine and immediately press ALT+F10. From there you will enter Acer eRecovery Management which will give you the option of returning the machine to the factory settings.
WARNING:
This will erase everything you had stored on the machine!! ie data files, pictures etc...
Apr 12, 2009 | Computers & Internet
This a very common error. I too have suffered from this but after about 15 hours of fighting with it.. I fix it. I could not use the ALT + F10 keys as I would get the D2D32 Type Mismatch Error. So lucky me when I got my laptop from acer I made the recovery DVD's just in case. But to my suprise Booting from the DVD disk also would fail with the D2D32 Type Mismatch error. I even try maken new recovery disk with some luck. the new disk worked one time. But I started to run the recovery on disk one and when it asked for disk 2 I hit the power button thinking it would still boot, as I didnt want to wait for the recovery process to complete. So I ended up with a acer laptop with no o/s installed and was not able to use the Alt + F10 as explaned above or Boot using the recovery DVD's... so how did I fix this little set back... simple
I broke out the windows xp install Boot cd and Booted my system with that. let it run all the way to the partation/Format section on windows xp setup. I left the partation as it was and formatted it with the quick option. BE VERY CAREFUL AT THIS STEP... MAKE SURE YOU DONT FORMAT THE WRONG PARTATION THE 9 GIG OR 10 GIG IS WRONG. IT WAS DRIVE LETTER F: ON MY SYSTEM. JUST MAKE SURE IT IS DRIVE LETTER C: THAT YOU FORMAT...After it was done with the format I powerd down the system and tried to Boot from the Recovery DVD and it worked. No D2D32 Type Mismatch error. "{ But I let it finish this time around"} So to keep it simple. all you need to do is keep the partation the same, just format it and it your recovery will work. both ALT + F10 and /or the DVD"S Boot. it the ALT+F10 by chance dont work... theres a quick fix also. you need to files called MBRwrWin.exe and RTMBR2.bin and they have to be on the root of drive c:...{Root - just copy them to C: } and then from a command prompt with Adminastration {right click cmd } and type MBRwrWin install Rtmbr2.bin <Enter> ALT + F10 is now ready and fixed...
if you need help let me know or just to give some feed back
email me at cyberburn666@yahoo.com
Good luck it works. I just went from on os installed to vista... with factory recovery working like the day I got it....
Jan 20, 2009 | Acer Aspire 5610-4648 Notebook
Acer 7520 reboot
It seems your recovery program is at fault
I googled this answer from this page
http://www.howtogeek.com/forum/topic/d2d32-type-mismatch-part-3-of-my-problems-
Hope it works
value to Enabled."
Nov 10, 2008 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Hi I have an Acer 5920, And im wondering how i can reboot it to it's factory settings. When i try ALT F10 It comes up and i do non-disk (partian drive) but when it processes it it comes up with an erre...
Ok, the computer, when purchased should have come with a Facotry Restore CD. If it did not, then the next step would be format and reinstall the operating system. Otherwise, Once a system has been used for some time, there are so many updates that the computer has automatically downloaded that there is no way to really work around them trying to restore the system to its factory settings.
One of the other reasons why your hard drive is coming back with an error on the partion is that if the hard drive hasnt been wiped properly recently, then when it goes to seperate the drive into multiple instances (i.e different parts to the same main equipment) the computer cannot proceed because it will find little files that are stored away in those Sectors. Like DLL files that were there from previous programs. or in some cases Randomly scattered registry files.
Oct 26, 2008 | Acer Computers & Internet
Acer Aspire 5520-5156 Laptop Logo
1,001 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
