Question about Toshiba DKT-2020-SD telephone
Unable to program buttons on the phone
How do I program my buttons with extension numbers. Also I do I program my name into the phone on the display, so when I call, people will know it is me.
  • 38 Answers
R u using CTX/CIT system??
this only apply for CTX/CIX
to set extn ket at flexible button
press  #9876
press  HOLD
press the flexible button u wanted to assign
press 610 follow by extn number
press again the plexible button to confirm
repeat step for other flexible button
to set name must go to administrate phone
press MODE at the display
press ADMIN
key in password
default password are ' 0000 '
press HOLD, display will show phone name
press HOLD, again will show DN ID
DN stand for extn
key in extn number then key in name
HOLD again to confirm setting
repeat step for other name
Posted on May 31, 2009
Hi I have a Nec DT300 at work. I am on a new desk. Do you know how I can change the name which is on the display.
If you have the Admin password then follow this procedure:
For a DT330 (24-Button with 4 line LCD)
Do not lift the handset and press the Speaker button
Enter #*#*
Enter the 4 digit admin password and press the Transfer button
The phone will now display 'Program Mode'
Select Base from the four options using the associated softkey
Enter 15 and press the select softkey 2 times
The Extension Number and Ext Name will be displayed
Find the Extension Number you want to change the Extension Name for using the + and - softkeys
Press the Mic button to go to the Ext Name line
Enter the New Name using the number dial keypad.
If you make an error the Recall button will delete a character to the left and the Hold button will delete all characters to the right of the cursor.
Press the Transfer button to accept the new name.
Press the Answer button 4 times or until 'Program Mode' is displayed.
Press the Speaker button.
The system will save the changes and return the display to normal.
Feb 14, 2015 | NEC Lands Phones
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
Phone not ringing in normal mode
I believe this is a programming issue.
To change the ringing assignments on extensions enter programming mode by pressing Feature **266344 and password 266344 if it hasn't been changed. You have to do this from an M7310 phone. The top two buttons on each side will move you through programming. The top right button is the SHOW button and the button below it is the NEXT button. The top left button is the HEADER button and the button below it is the BACK button.
Your first category should be TERMINALS & SETS. Press the SHOW button and using the dial pad enter the extension number. The display should show the extension number or name. Press SHOW three times and the display should show LINE ___.
With options to SCAN or LIST. Pressing SCAN will show the lines assigned to the extension. Use the CHNG option to change how the line is on the phone. RING ONLY - UNASSIGNED - APPEAR ONLY - AND APPEAR & RING. Change the lines you want to ring in NORMAL DAY MODE to APPEAR & RING for this extension and press SCAN to move to the next assigned line. Use this same method for any extension you want to change the ringing on.
Dec 18, 2013 | NorStar M7310 Corded Phone
How do I change the name display on the MLX-28D?
A label can have a maximum of seven characters.
To administer Labels for Extensions from the System Programming console:
  1. Press Menu.
  2. Press System Program.
  3. Press Exit or Start.
  4. Press More or Right Arrow Key.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  8. Dial the extension number that you want to administer.
  9. Press Enter.
  10. Press Drop.
  11. Enter the label information for the extension number selected.
  12. Press Enter.
  13. Press Exit or Back.
  14. Press Home or Exit to exit programming mode.
Note: When programming on the system programming console, use the buttons next to the display to specify the letters A through I and punctuation. Use the line/feature buttons to specify additional alphanumeric characters for labels. Use the template provided with the System Programming console to see which line buttons correspond to which alphanumeric characters,
Jan 07, 2010 | Lucent Legend MLX-28D Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
I need to know how to change the names on the extensions
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Sep 10, 2009 | Avaya 4424D Corded Phone
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Need to change extension names on a MLX-20l phone
http://dstech1.com/changing-the-name-on-an-extension/
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Jan 13, 2009 | Lucent Merlin Legend MLX-10D Phone
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
Jan 12, 2009 | Panasonic KX-T7730 Corded Phone
Lucent MLX-20L Extension Edit
  1. Press Menu.
  5. Press Labeling.
  6. Press Directory.
  7. Press Extension.
  9. Press Enter.
  10. Press Drop.
  12. Press Enter.
Dec 22, 2008 | Lucent Merlin Legend MLX-10D Phone
Toshiba DKT-2020-SD telephone Logo
537 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
