Question about Panasonic PT-47WX53 47" Rear Projection HDTV
No green color in picture?
We've had no problems for almost 5 years, but we just lost all color in our Panasonic rear projection TV. Is it a simple fix or do i need to buy a new TV?
Can anyone HELP?
  • 822 Answers
Its a simple fix. just go to your menu in TV adjust the RGB color. balance the RGB settings.
Posted on May 26, 2009
I have a hitachi 54' projection tv model num.57SWX20B i purchased about 8 years ago brand new. when turned on operayes fine for about 5 mins. then i lose my picture to multicolored lines after a couple...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Picture has a problem lost a lot of the color
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Where are the convergence ic's located on a Panasonic pt-56hx40?
On the board on the left...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Panasonic PT-56HX40 56" Rear Projection...
Lost picture
When was the last time u replaced the projection bulb,yes it could be that simple the projection bulb it dead.The bulb last only about 1 or 2 years,by using the tv on about 4 or 5 hours a day.
Jun 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My panasonic projection tv is showing green spots what could be causing this problem.
If you have colored ~1" spot(s) it is most probably associated with EPROM (memory chip) defect. In that case the TV internal computer should be reprogrammed by a certified technician. They fixed mine that I bought in 2006 (4 years) ago FOR FREE.
I called Panasonic using the phone number in the manual (1-888-843-9788), selected Service, told that I got the problem which is most probably "a manufacturer's defect" that should be fixed for free - they redirected me to the next step, then to the next one and in about 20 minutes they arranged me a home-visit by a support person (the guy had to drive 2 hours to get here!).
The service guy came in two days, unscrewed the back panel, connected some kind of a box to one of the boards, turned TV onto some channel and let the box do its job for about 5 minutes - then all of a sudden the spots disappeared and the picture is OK now.
Apr 16, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
PANASONIC PTK-4077S PROJECTION
You need to adjust screen drives on Red Green Blue tubes ,does all 3 of them light up? Focus/screen control box is in front of TV behind front panel Turn color off then adjust all 3 tubes to where you have a black and white looking picture, now turn color back on.
Dec 27, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Panasonic T.V...
What is your tuner source? Cable,Satellite, antenna?...accordianman
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
199 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
