Question about Acer Extensa 5420-5687 Notebook
Connect burner and restart player
When i tried to burn a cd it said connect burner and restart player. i've tried to uninstall the cd/dvd drive and reboot assuming that it would come back up when rebooted but it didn't. what should i do?
    Scholar:
  • 57 Answers
You arent the only one with this problem, and Acer has neglected to provide any info or fix.
The best I can do for you mis to suggest that you try the following,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
Apparently it seems that this is an age old fix for even XP systems. If you venture to the registry key above by doing the following steps:
  1. Click on the start menu.
  2. If this is a Vista machine in the search box type in “regedit” without the quotation marks.
  3. Maximize the HKLM and then go ahead and browse until you reach the key listed above.
  4. In the right panel you’ll see something along the lines of “UpperFilter” and “LowerFilter” you want to click on each “filter” key and hit delete. Click yes when it asks to confirm if you wish to delete the key.
  5. Restart Windows.
  6. Let me know if this works.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
Posted on May 26, 2009
Wont read or write to samsung sw 248 drive i've uninstalled and rebooted drive and drivers, deleted all burning software i have itunes but used to be able to burn music before cant do anything now put...
HI,
This is gonna be a bit complicated since were going to access your registry, but just follow all the steps and it will be much easier
1. Click on START
2. Type REGEDIT on the search bar on START Menu on the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
If nothing happens, click on this link then click on RUN and follow the steps, then restart computer and try to run a disc again, if still nothing happens, theres a possibility that the problem is with the hardware side or the media player that you are you using...
Hope this will help...Thank you for using Fixya...
Jun 22, 2011 | Samsung SW 248 CD-RW Burner
My sony crx320ee cd-rw/dvd stop functioning normaly, cannot burn cd now. plz hlp!
i would recommend uninstalling the drivers completely and reinstalling them, however most drivers for cd roms cd/rw are preinstalled, and the only thing you can update is the firmware for the device itself. you may want to try unhooking the drive and rebooting the computer, then turning off the machine again, and reattach the drive, and restart. that might force it to re-configure and re-load the drivers
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Dec 29, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
The player will play dvd and cd. Will not burn
  1. Check the DVD format,maybe the dvd your trying to burn is not supported by your DVD writer
  2. Check the surface of the disc.If is dirty or scratched
  3. Make sure that DMA is enabled on your IDE channels in the "Windows Device" manager(right click on My Computer and select Properties.Hardware->Device Manager )
  4. Uninstall every DVD program you have
  5. Reboot
  6. Verify that your hard drive has enough empty space so it could burn something
  7. Install the program
  8. And try again
Jan 19, 2010 | Gateway Computers & Internet
My drive will not burn dvd-r anymore but it used to, it burns cd-r and reads discs no problem, but now when i try to burn the disc spins but makes a strange knocking noise.
sometime it has more to do with the driver software than it does with the unit itself.
Try uninstalling the writer software, restart the computer, reinstall the software, restart the computer, and attempt burn again. Software occaisionally gets confused and needs to be "rebooted" from time to time. Hope this helps.
Oct 12, 2009 | BenQ DW1670 Double Layer 16 DVD RW IDE...
Says there is no cd burning device, does not recgonize cd burner/dvd player
can you try the drive any where else.If not go under device manager and uninstall the drive,reboot see if it will tell you new device found.
good luck
Sep 09, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Connect a burner and restart the player
Open REGEDIT
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
In right pane select UpperFilters - do an Edit/Delete
In right pane select LowerFilters - do an Edit/Delete
Exit REGEDIT
Right click MY COMPUTER
Properties
Hardware
Device Manager
Uninstall your CD/DVD player/burner
Restart the machine - it will find and reinstall your burner and you'll be good to go
Note: if your uncomfortable deleting registry entries, rename them (e.g., w/ ".SAV" extension)
May 19, 2009 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Trying to burn cd keeps saying reconnect burner
try going to device manager, uninstalling driver, rebooting and it should reload drivers automatically after boot.
if doesnt reload them you can download them from dell's website
Apr 12, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Media player says that it cant find the burner
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Dec 31, 2008 | Samsung SD 616E (729507925578) Internal...
Can't burn an audio cd on my dell inspiron 1525
do one thing
go to the my computer > right click on the burner drive > properties > recorder > and than chk if that the recording option is checked or not
if not check it
if it is alread there
right click on my computer > properties > hardware > device manager > click on cd /dvd drive and uninstall the options there
than click on the IDE / ATA
and uninstall the secondary chanel first
and uninstall the primary channel .... but be sure that you do this in the same sequence coz if u have a ATA hard drive thats normally connected to the primary channel and if u uninstall that first it will freeze the system... after that is done restart the system and issue resolved
Dec 06, 2008 | Dell Inspiron 1501 Notebook
Can not burn cd or dvd on on double layer burner
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check ENABLE cd recording on this drive driver - update or uninstall reboot your computer 3. go to support.toshiba.com look for the EXACT model of your toshiba notebook a) download latest BIOS b) download the cd driver Goodluck!
Oct 03, 2006 | Toshiba (SD-R5372V) DVD RW Dual Layer...
Acer Extensa 5420-5687 Notebook Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
