Question about Comtrend CT-507 Router
Router login I need to log into my router but I can't remember the login name and password. The router is a CT-5621 Multi-port ADSL2+ Router.
    Brigadier General:
  • 6,966 Answers
If your Comtrend CT-5621 came with the package from your ISP then it is possible that the username and password has been changed by your provider and you would have to get in touch with them.
In some instances the username is "root" and the password is "root".
Some known passwords from ISPs are:
Canadian Broadband/Aliant - RM60008
NetComm - NetC0mmV3oo
Some ISPs disabled/blocked the web based configuration interface and the initial way to communicate with it is a telnet session to the router.
Would you know if your default IP address of 10.0.0.1?
Good luck and kind regards.
Posted on Oct 21, 2007
Comtrend CT-5621T reset
Most routers are the same. admin/admin or admin and no password.
Oct 12, 2012 | Comtrend CT-5621T 4-Port ADSL2 USB...
Forgot pasword router
did you change the password ?
Click the "Wi-Fi" network icon located on the Window's taskbar.
Right-click the name of your network's "SSID" name and select "Properties" from the drop-down menu.
Click the "Security Tab." The network security key is now visible but unreadable.
Click the "Show Characters" check box and this will reveal your wireless password.
or
Log in to the router.
Routers typically have the IP address "192.168.0.1" or "192.168.1.1" for their configurations.
When connecting to the proper router IP address, a password box appears. The default login for Linksys routers is no username and "admin" for the password.
The default login for most other routers, including D-Link, Netgear and Belkin, is "admin" for the username and "password" for the password.
View or change the wireless password.
This is either a WEP key or a WPA/WPA2 password.
Some routers allow the direct viewing of the password, while others mask the password.
If the password is masked, the only option is to change the password to something else.
Connect to the wireless network with either the revealed or changed password.
Recover the System Password
Hold in the reset button on the router for 10 seconds and disconnect the power.
Continue to hold the reset button for 15 seconds while reconnecting the power.
Release the reset button and wait 60 seconds.
The router has now been reset to factory default settings.
Log in to the router as in the previous section.
Hope this helps
Sep 25, 2012 | Thomson Genuine Unbranded Tg585 V8...
How can i cascade a Comtrend CT-5621 with a Netgear Wnr2000v3
works best if you hard wire from LAN port of main router to LAN port on second router. 2nd router never has anything plugged into internet port. 2nd router has dhcp turned off. 2nd router has a ip inside the 1st routers ip range but not the same as anything else
Jul 06, 2012 | NetGear WNR2000 Wireless Router
I am using dlink wireless router. How can i restrict unauthorised users accessing net through my connection?ADSL2+router
By using your wifi security.
Log on to the router and turn on WPA2 security, choose a password, and you should be ok
Sep 23, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Problem with DSL2640U wireless router
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Jul 29, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I change channels on the 4 Port Wireless Router, ADSL2/2+. Need to change from channel 9 to channel 1.
Manual for DSL-2640B:
ftp://ftp.dlink.co.uk/dsl_routers_modems/dsl-2640b/DSL-2640B_Manual_v1.pdf
How to change channels see page 27.
For manual channel setting "Enable Auto Channel Scan" needs to be
disabled / not selected.
Note: default login user and password for the router is both admin.
Login opening Internet Explorer entering http://192.168.1.1 as address page.
Sep 01, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I can not remember my password so i can use my wi fi. So how do i reset my password. i can log on to the router can i change it in the settings?
Reset
Pressing the Reset button for 5 seconds restores the router to its original factory default settings.
Log in to the Router
This section will explain how to log in to your router using the following steps:
1. Launch your web browser.
2. Enter the URL http://192.168.1.1 in the address bar and press Enter.
A login screen like the one below will be displayed after you connect to the user interface.
Note: There are three account types, each requiring a different username and password.
• The user account provides limited access to certain configurations (username / password: user / user).
• The admin account can perform all functions
(username / password: admin / admin).
• The support account is for ISP technicians for maintenance purposes
(username / password: support / support).
Note: Passwords can be changed at any time.
3. Enter your user name and password, and then click OK to display the user interface.
Note: This manual has been prepared using the admin user name
Aug 20, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Jun 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
Ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Mar 01, 2008 | Comtrend CT 300 (CT-300) Modem
Comtrend CT-507 Router Logo
1,422 people viewed this question
Top Comtrend Computers & Internet Experts
Marvin
Marvin
Prashant M
Prashant M
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
