Question about Kenmore Washing Machines
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
My son just pushed in something on the door latch and now my Kenmore front loader will not lock. It looks as if it is already "locked" but the door will not close and lock. This is a Elite HE3T
  • 15,935 Answers
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
HOW TO TAKE LOCK OUT OF GLOVE BOX DOOR HANDLE?
Hello, to take lock out of the glove box door handle you have to follow these steps:
1. You have to open the box door.
2. Push latch to close position
3. Put in lock position and remove the key
4. Push in tab
5. Insert the key
6. Turn the key to unlatch the position and pull lock out.
7. If latch needs to be replace, UN-screw collar
8. Reverse to re-install .
Thanks
Jun 29, 2011 | 1993 Chevrolet Caprice
My BMW x3 2005 back door will not close. The latch doesnt seem to catch. We tried locking and unlocking the doors you can hear the mechanism working but latch is catching. Lock/latch seems to just spin...
Hold down the "open" button on your remote and simultaneosly pull the inside handle of that door open. I just had the issue with my driver's door and as my son tried to "help" (he's 9), one of the passenger doors also got stuck! After not finding a non-tech response, played around some until the the dran latch obliged on the front door. Repeated on passenger door and whew! :-)
Mar 18, 2011 | 2006 BMW 3 Series
2004 Volvo V70 - can't close the rear passenger door - seems like the latch won't move out of the way to close the door - the latch is in the down position. Tried locking and unlocking - tried the child...
I HAVE A Volvo v70 2005 Everything is dead on the passenger door. no centre lock or window actuvation. The bad part I cannot open the door ( I think when there is no electric to the door the ded bolt keeps the door locked. How to get the door open so I can take the trim panel off to see why there a problem
Feb 18, 2011 | 2004 Volvo V70
Door won't close
You have probably bumped the latch and caused it to close. Look at the latch in the door. The latch has a locking arm that is down when in the locked position and up at the top when in the open position. If the arm is down in the center of the latch opening of the door push the arm upward until it locks in place.(sometimes you have to activate the latch handle/button on the outside of the door while pushing the arm upward)
Dec 13, 2010 | 1997 Pontiac Sunfire
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Passenger side door lock isn't locking
youve got the latch in the closed position you need to take a screwdriver and use it to push the latch back down so the door will close again,
Feb 14, 2009 | 2005 Chrysler PT Cruiser
Bosch SHU43 / Siemens Dishwasher door not locking
I replaced the top cover, that required removing the door screws to get access to the front of the door to remove the 4 top cover retaining screws. After replacing all this, the door latch was in teh locked position not allowing the door to close. How do you physically re-set the lock, I tried to push it with no luck!
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Washing Machines Logo
189 people viewed this question
fordexpert
Mike Squire
Robert Rankin
