Question about Zanussi ZEBF250W Bottom Freezer Refrigerator
Freezer Icing Up
We have a Westinghouse BJ504M Frost Free (ha) fridge and the freezer compartment (located below the fridge section) keeps icing up. If switched off and manually defrosting the freezer, when switched back on and left overnight the ice returns next morning. If left for a week, the freezer drawers get covered in ice so bad, you struggle to open them!
I contacted the technical hot-line and after discussions (3 separate calls) have replaced both fridge and freezer door seals, thermostat and all the door hinge bushes (thimbles). The problem is STILL there.
Can you please help before I pull out what hair I have left?
Thanks
Colin
  • Anonymous May 13, 2008
    We have the same problem with our frost free appliance. It gets so bad you can't really be sure the door is closed, and it opens when you use the fridge compartment. Only solution so far is to turn off and manually de-ice.
    It's a Zanussi ZK73/34EF(S).
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 160 Answers
Try contacting the hotline again and ask them if the freezer has a frost sensor on it. If it does, the sensor is not kicking the thermostat to allow for the unit to defrost.
Posted on Oct 21, 2007
My Westinghouse Frost Free fridge is not working. The freezer is working. It is has the freezer on top of the fridge, separate doors
Even though it is frost free, try defrosting it by turning it off with the doors open for a few hours. There may be ice or something else blocking the vent between the freezer and refrigerator sections. Of course you will need to remove everything from the fridg and freezer and store it somewhere else that is cold.
Dec 22, 2014 | Westinghouse Refrigerators
Freezer is frost free yet it is icing up its a refridgerator
I would recommend that you turn either the freezer down or the fridge. This is somewhat normal, even frost free units will produce some frost, and this is mainly due to the temperature being too cold. Some minor adjustments and you will be fine.
Mar 20, 2011 | Westinghouse Refrigerators
ICING UP FREEZR
this sounds like a defrost timer issue possibly a bad defrost heater is also involed,what was done the first time seems like it needs to be done again.some thing is not telling it to go into a defrost mode may be a sensor issue as well. good luck with this problem
Jan 21, 2010 | Samsung RS2630SH Side by Side Refrigerator
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Our beko frost free fridge freezer has stopped freezing. The fan is working and the freezer section cold but not cold enough. Thermostat is in the fridge - the fridge is icing up.
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Aug 12, 2008 | Refrigerators
Frosty
IS THE BACK OF THE FREEZER CLEAR ICE OR WHITE FROST?
IF IT IS WHITE FROST, THERE IS A FAILURE OF THE DEFROST CYCLE. THREE COMPONENTS NEED TO BE CHECKED. THERE IS A DEFROST TIMER, HEATER AND BI-METAL. THE HEATER AND BI-METAL ARE LOCATED BEHIND THE BACK WALL OF THE FREEZER WHERE THE FROST IS BUILDING UP. IF IT IS A WHIRLPOOL, THE TIMER IS LOCATED IN THE FRESH FOOD COMPARTMENT WITH THE COLD CONTROL. LOOK FOR A HOLE THE SIZE OF A DIME IN THE CONTROL HOUSING. THERE IS A SMALL DIAL IN THERE THAT CAN BE ADVANCED WITH A SCREWDRIVER.
ADVANCE IT UNTIL YOU HEAR A STRONG CLICK AND THE
REFRIGERATOR SHUTS OFF. THAT WILL BE IN THE DEFROST CYCLE. WAIT ABOUT TEN MINUTES AND LISTEN FOR SIZZLING IN THE FREEZER COMPARTMENT. ALSO LOOK FOR A RED/ORANGE GLOW IN THE FREEZER. IF THAT HAPPENS, THE HEATER AND BI-METAL ARE O.K.
REPLACE THE TIMER. IF NOT, TAKE THE BACK PANEL OFF THE FREEZER AND CHECK THE HEATER AND BI-METAL WITH A VOLT-OHM METER. REPLACE THE DEFECTIVE PART.
ON G.E. REFRIGERATORS, SOME HAVE THE TIMER LOCATED BEHIND THE TOE PLATE AT THE BOTTOM OF THE REFRIGERATOR. ON OTHER REFRIGERATORS, IT IS LOCATED INSIDE THE COMPRESSOR COMPARTMENT TUCKED BACK IN A CORNER.
Mar 31, 2008 | Refrigerators
Zanussi ZEBF250W Bottom Freezer Refrigerator Logo
567 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
