Question about Whirlpool GEW9200L Electric Dryer
Duet whirlpool dryer not running
All lights are on and working but dryer does not start when stert button is pushed.
If it is the 9400 series, the door has 2 latches. It must be shut firmly to connect. Sometimes it will take 3 or 4 firm shuts. I feel it is a design flaw of the door. Hopefully this helps as I have been struggling with it for 2 years.
Posted on Jun 06, 2009
  • 56 Answers
Must be the thermal limit on the blower housing I believe acess is from the back unplug take off back acess and look for a small white thernal limit (plastic fuse) on the blower housing. take it to a dealer to check or ohm it out it should have continuity
Posted on May 29, 2009
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Duet electric dryer WED9400SW0 dryer turns on but when I push and hold the start button it won't start rotating. It worked fine all weekend and then today, nothing. Help??
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Mar 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
My Duet Electric Dryer control lock light on and will not turn off and dryer will not start.
I had this happen..push and hold the signal button for about 3 secs this should unlock it. Thats what worked for mine.Good luck hope it helps
Jul 17, 2010 | Whirlpool GEW9200L Electric Dryer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
No start
e3 fault??? sounds like an open sensor, located right nest to the thermaal fuse.
May 08, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer (2yrs old) Light buld died and dryer won't start. We changed bought a new light bulb but the dryer still doesn't start. The computerized buttons still litght up though.
Sometimes when a bulb goes out or is replaced the unit can short out.
Try holding your end of cycle signal button for 5 seconds, watch the light, if you control lock it, it will light but will not run because control lock is a safety feature.
Also try pushing door in and starting it, might be bad latch
May 02, 2008 | Dryers
Whirlpool GEW9200L Electric Dryer Logo
219 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
