Question about Intel Motherboard
About pc when i on my pc it show a message that in 'c/program files/my web/bin/m3plugn.dll/not found' what i can do that messege not show at startup
  • 749 Answers
This is telling you that the myweb is not installed correctly or has been uninstalled incorrectly. More than likely someone deleted it instead of uninstalling it which left the reference to the program in your windows registry causing windows to look for a file that is not there which would give you that error message.
First, uninstall the My Web Search option from Add/Remove Programs
1) Click on Start, Settings, control panel
2) Double click on Add/Remove Programs
3) Find "My Web Search" in the list of installed programs and click on Change/Remove to uninstall it. You may also want to uninstall any of the following items associated with FunWebProducts.
  • My Web Search (Smiley Central or FWP product as applicable)
  • My Way Speedbar (Smiley Central or other FWP as applicable)
  • My Way Speedbar (AOL and Yahoo Messengers) (beta users only)
  • My Way Speedbar (Outlook, Outlook Express, and IncrediMail)
  • Search Assistant - My Way
4) Reboot your Computer and run HijackThis
5) With HijackThis, scan for and fix any of the entries shown above that may be remaining.
6) Next, open My Computer, Drive C, and double-click on the Program Files folder
7) Right-click and delete the folders for:
  • FunWebProducts
  • MyWebSearch
8) MyWebSearch should now be completely uninstalled from your computer.
9) There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy or Ad-Aware SE or left alone.
Regards..
Posted on May 26, 2009
Error message rundll on startup
Looks to be a left over file. Probably not needed - this happens when you delete a program, but other files remain. Go to start button - click on search - click on all files and folders type lumejeji.dll in the top box - hit the search button
it will find the file - you can either drag it to the recycle bin or right click on the file and go down to delete and left click that.
Should fix your problem
HOWEVER
I just looked this .dll file up - Here is what I found - you may want to delete the file and run a virus scan as well
hope this helps
UMEJEJI.DLLFraudulent Security Program Your PC is infected. The file called LUMEJEJI.DLL is considered unsafe and there may be other infections on your PC.
You should urgently check your PC and remove any malicious software including LUMEJEJI.DLL as soon as possible.
Dec 30, 2008 | Dell Dimension 4600 PC Desktop
@ start error message C:\PROGRA~1MYWEBS~1\bar\6.bin\M3PLUGIN.DLL
It seems this dll files is set to load at start up and would actually seem a virus of some sort, nevertheless, this file is not necessary and should be removed from the system and is already removed, all you need to do is disable this file to load at start up follow these steps:
Start>>>Run>>type msconfig>>go to the start up tab and look for the entry that is loading the dll file on startup>>uncheck the entry click apply then click close, restart the pc and the error message should not pop-up anymore.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 31, 2009 | Microsoft Windows XP Professional for PC
Missing m3plugin.dll
Hi ssponheim,
this is a common issue with the program. (MyWebSearch).
Try this. Right click once on the start button, (Apop-up window will open), slide up to Explorer & left click on it once. Right click once on the C: drive & left click Search. In the search top window type the name of the file: m3plugin.dll
Click search.
Windows will find the file. Right click once on the file m3plugin.dll listed in the right hand side of the window & left click Copy. Windows Explorer is still opened. Scroll down to the folder Program Files & left click the plus sign next to it. Program Files will open & you'll see all kinds of folders.
Find the Mywebsearch folder & open it. Find the folder 1.bin Right click once on that folder & left click past.
Close all opened windows & restart the system.
The program will function again without an error message.
More troubles? Post your question here.
Mike
Nov 13, 2008 | Compaq Presario 5000 PC Desktop
M3plugin.dll missing module at startup
Your web browser has been hijacked by "adware" called "My Web Search"... The fix is involved, but not impossible.
First, uninstall the My Web Search program using standard Add/Remove Programs. Also uninstall any of the following items associated with FunWebProducts.
Download a free copy of a program called HijackThis.
Reboot your Computer and run the HijackThis program.
Scan for and fix any of the entries shown below.
  • R3 - URLSearchHook: (no name) - {00A6FAF6-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: MyWebSearch Search Assistant BHO - {00A6FAF1-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
  • O2 - BHO: mwsBar BHO - {07B18EA1-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O3 - Toolbar: My &Web Search - {07B18EA9-A523-4961-B6BB-170DE4475CCA} - C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL
  • O4 - HKLM\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - HKCU\..\Run: [MyWebSearch Email Plugin] C:\PROGRA~1\MYWEBS~1\bar\1.bin\mwsoemon.exe
  • O4 - Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O4 - Global Startup: MyWebSearch Email Plugin.lnk = C:\Program Files\MyWebSearch\bar\1.bin\MWSOEMON.EXE
  • O8 - Extra context menu item: &Search - http://bar.mywebsearch.com/menusearch.html?p=ZWYYYYYYYYUS
  • O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - http://ak.imgfarm.com/images/nocache/funwebproducts/ei/MyWebSearchInitialSetup1.0.0.8-2.cab
  • FunWebProducts
  • MyWebSearch
There will be some minor registry entries left behind by the uninstall, however these can be cleaned up by running SpyBot Search and Destroy. SpyBot is also available online as a free download.
Good luck!!
Sep 11, 2008 | Microsoft Windows XP Home Edition
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
C:PROGA~1\MYWEBS~1\bar\1.bin\MP3PLUGIN.DLL
I am running XP. I went to RUN - MSCONFIG, then go to START tab. You will find an entry for this DLL. Uncheck to box, choose APPLY, and restart your PC, the nagging pop up on restart should be gone.
Aug 01, 2008 | Computers & Internet
M3plugin.dll
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
M3plugin.dll
progra-1maywebs/bar/8.bin/mwbar and 8.bin/m3plugin.dll .may problem with computer
Jun 02, 2008 | Intel Motherboard
Window proffectional 2000
This message occurs when a "run key" still exists in the registry for an item that has been removed from your machine.
In this case, you would just "fix" it with HJT to remove the key from the registry.
If you still have Mywebsearch active, the first step would be to uninstall it via Add/Remove Programs.
Failing that, open the C:\PROGRAM FILES\MYWEBSEARCH folder and run the uninstaller manually. If no uninstaller exists, you could just delete the folder and clean registry remnants manually, to the extent desired - (most just remove the runkey and leave it at that).
Mar 19, 2008 | Microsoft Office Outlook 2003 for PC
Hi rahul
Is this problem regarding your office or something else.
As it seems this is about my web search toolbar utility which you had installed earlier .
You run the msconfig utility using the run command from start menu.After this disable the startup item for mwsbar.dll and exit.
You look for the program files and search for MyWebs folder and delete it.
And it will work fine.
Don't forget to give fixya rating to this.
Feb 14, 2008 | Microsoft Windows 2000 Professional for PC
Intel Motherboard Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
