Question about Casio G-Shock GW500A-1V Wrist Watch
Automatic backlight i would like to know the procedure on how to turn on the automatic backlight that is when you tilt the watch on that angle,the light automatically turns on.
  • repax Dec 01, 2007
    thank you very many. . .Guest
PUSH AND HOLD THE MANUAL LIGHT BUTTON, SHOULD CHANGE TO AUTO MODE
Posted on Nov 04, 2007
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
Tip
HOW TO START YOUR AUTOMATIC WATCH
mcdevito75 here,The Automatic feature in your WATCH consists of a counter-weight attached to the MAIN SPRING by a gear that allows a SLOW but steady wind of your watch with the motion of your WRIST, ARM. Once, only in HIGH END watches, today almost all watch manufacturers have this feature in some of their models. Everyone who owns an AUTOMATIC watch knows, you can START your AUTOMATIC watch by WINDING THE STEM and you can continue to wind the stem with no end. This will at least START your AUTOMATIC watch and, this is true to some extent BUT, does this apply to my watch you ask?, Here"s how to tell if your AUTOMATIC watch will START with a few winds of the stem or not. ------- Very Simply, Hold your AUTOMATIC watch to your ear and wind the stem, if you hear a sound as though something is DRAGGING or the stem feels slightly stiff one way you wind the stem and you hear a clicking sound when you wind in the other direction, then you have the TYPE of AUTOMATIC watch that will start with a few winds of the stem, approx, 20 turns or winds. If on the other hand you hear nothing when you wind the stem and the stem feels very loose when turnning then you have the TYPE of AUTOMATIC watch that winds only with the motion of your wrist / arm, to start this type of AUTOMATIC watch, simply hold the watch in your hand and rock your watch back and forth, say from the 12 O"clock to the 6 O"clock, and or, Hold your watch securely in your hand a make circular motions with your hand, any movement to get your watches counter-balance to turn and thus wind your watch. Approx. 1 minute of this extra motion will start your AUTOMATIC watch, then simply wear your watch and your wrists / arm motion will keep it wound.
on Jul 06, 2010 | Watches
Tip
TAG HEUER automatic watch with turning bezel (GMT) manual.
Follow this link and download original manual for TAG HEUER automatic watch with/without turning bezel and GMT function: http://www.tagheuer.com/the-collection/link/men/automatic-watch/index.lbl?w=WJ201A.BA0591
on Feb 09, 2010 | Watches
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
Dont know how to set date on an automatic watch
mcdevito75, Here, You can set the date on your Timex Automatic, by simply slipping your fingernail just under the stem (winder) and gently lift it up to it"s first position (notch), this will allow you to turn the stem to change the date without haveing to turn the hands so many times. once set push the syem back in.
Jun 20, 2010 | Timex Automatic Watch
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
Oct 15, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I don't know how to turn off the automatic light feature on my watch
There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
What is the procedure to make the watch switch the face backlight on Automatically when i tilt my wrist. The manual switch works ok ...the backlight turns on when pressed.which set of "buttons" do i need...
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 31, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Problem winding a Invicta Skeloton Mechanical Stainless Watch
The Tag Heur repair center says an automatic watch must go through an "initiation" process. They recommend winding manually 40 revolution of the crown clockwise. You must wear an automatic watch at least eight hours per day. Repat the initiation if the watch is not worn for 20 hours or so.
Dec 12, 2008 | Invicta Watches
Small 'eye' icon??
The "eye" icon appears when you have your backlight set to auto. that means when you move your wrist to look at your watch the light comes on automatically. I have found this to be a huge drain on the life of the battery. to turn it off hold down the light button (the grey button on the front with the red "g" on it) untill you hear it beep.
As for the watch dieing when the alarm goes off that is a good indication that you need a new battery.
Mar 08, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW500A-1V Wrist Watch Logo
512 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
