Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
New ms230 stihl chainsaw won't start
When pulling starter cord, good spark from plug. Put petrol down plug hole still won't fire. Anyone got any ideas what the problem may be and hopefully a solution!!!
  • stevenedward May 28, 2009
    ok will give try,many thanks
I have a MS180C, and I had the same problem. I discovered that the saw is very tempermental with the amount of fuel in the tank. If you fill it even a bit over the fill line (in the horizontal position) the saw will not start. It will mean re-fueling more often, but you cannot fill the tank "full", only to the line or below.
Posted on Aug 29, 2012
Sounds like its flooded pull the plug and run pull it a few dozen times to dry it out. then try again
Posted on May 27, 2009
Stihl leaf blower won't start. Good spark . Replaced plug. Attempted start, negative, removed plug, plug dry. Primed, thumb over plug hole, pull cord, thumb dry. Tiny starter fluid, negative result.
Try and see if it will start with a tiny amount of fuel poured into the block. If it fires then it could be the gaskets on the carb need replacing or it could be a blocked air filter. Check the later first.
Apr 22, 2017 | Stihl Garden
My 4 stroke petrol lawnmower engine won't start - where's the problem?
Hi try a new spark plug check if it's got petrol check for spark put the lead on the plug before U put it in hold the side of plug on the mower & pull the cord to c if it's got spark.. check for compression put your finger over plug hole & pull the cord if it's got compression it should push your finger away good luck
Nov 16, 2016 | Garden
Small gas engine won't start
hi u need 3 things for a motor to run spark petrol and compression buy a new plug earth it on the side of the motor with lead on it and pull the cord to check spark///// next pull the cord with youre finger over plug hole to check for compression and last check for petrol in carby it might need a clean ......good luck. .
Sep 17, 2015 | Garden
Does a ***** boy 50cc have a reed valve? Bike
Hi first thing what is the bike second thing is the engine a 2 stroke, if it is 2 stroke it most prob. has a reed valve, check that the carb needle valve is working as it should, then drain the cylinder and crank of fuel check the plug sparks, leave the carb off and put a small amount of petrol in it, try and start it if it fires once or twice, then it should start with the carb on it, if not there is a problem with the carb. good luck.
Sep 12, 2014 | Motorcycles
How to test ignition coil on a stihl ms290 chainsaw?
remove spark plug .put new one on to plug lead make good earth.turn ign. on pull over check for a good blue spark.
Jul 06, 2014 | Stihl Ms310 Ms290 Ms390 Complkete Starter...
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Homelite power washer too much oil
Hi Martin, check the level of the oil in the engine, if the level is low, the machine has been tipped on the side and the oil has gone over the head. Make shore that engine is on the flat ground when used or transported. Tilting the unit over 20 degrees will cause the oil to go over the head. Two ways to fix the problem pour some petrol in the cylinder, put a rag on the spark plug hole and pull the starter rope few times to clean the cylinder, repeat the same until the cylinder is clean. You have to check the carbi for oil getting into it, and clean it. Make sure you clean all the petrol before attempting to start the engine. It is a bit messy but not require to pull the engine apart. The other way to clean the oil is to remove the cylinder head off and clean it, its the proper way of doing the job, but requires a lot of dismantling. Hope this helps. Cheers
May 19, 2014 | Honda Pressure Washer PSI 3000
After starting and operating the chainsaw for a short time, it dies and I can't get it started again. Suggestions?
Engines require 3 things. Spark, compression and fuel. And chainsaw need 2-cycle oil mixed with the gas.
Assuming you have the right oil-gas mixture and a fresh batch of gas, and you didn't leave old gas in the saw all summer long since last November.
-Take off the dirty air filter and see if saw starts without filter. Do not run without putting in new filter.
-Check exhaust port for mud dobber home or screen clogged with carbon and dirt
-See if saw fires up after squirting WD-40 directly into carburetor
-Check gas line >>> pull gas line loose and see if gas flows out of tank to carburetor
-Take out spark plug > put finger over spark hole and pull cord >> do you feel suction that says you got compression?
-Put spark wire back on spark plug >>> hold spark plug so threads touch bare metal part of spark plug hole >>> pull starter cord and see if spark shows between plug and saw >>> suggest you not hold metal part of spark plug while pulling cord [you'll understand why]
-If spark plug shows spark, then your saw has spark ... so put in new plug and start fresh.
If your saw has compression, spark, and fuel it should start unless carburetor is gummed up because gas was left in tank.
Here is the final trick. Start the saw while spraying WD-40 directly into carburetor and see if you can keep it going with the WD-40. This might take a helper. If this does not work, then carburetor is bad or gas line is clogged at carburetor. Time to take it to the shop.
Oct 06, 2010 | McCulloch Garden
ENGINE WILL NOT START
My power-washer suffers from same problem after sitting idle.
After paying for a new carburetor, I discovered how important it is to drain the gas if washer is going to sit idle.
Another time, we had a problem with the screen covering exhaust outlet. Deposits from the engine + dirt clogged the screen. Although it's not the solution for everybody, we broke the screen open with a screwdriver and the machine ran fine after that.
Small gas engines require 3 things. Compression, spark, and fuel. Take out spark plug. Put finger over spark plug hole and pull cord or push starter. Do you feel suction? If yes, then you have compression.
If machine will not turn over at all, then your motor might have run out of oil. Power washer needs oil in 2 places. It needs oil for the engine just like a lawn mower. Oil plugs are located low on each side of engine. It doesn't hurt to change oil, but do NOT NOT turn small engine upside down or oil will get into carburetor which requires removal and cleaning. I learned that the hard way.
The power washer also needs oil for the pump head. This is the box attached to front of engine. Usually 10W20 non-detergent is a good choice. Oil is usually about half way up inside pump head.
Now hook spark-wire back to spark plug. Hold spark plug in hand. Touch threads of spark plug to metal spark plug opening. Now pull cord or push starter. Do you see sparking in the spark plug gap? If yes, then you have spark. Put new spark plug in anyway. If no, then you need parts from small engine repair service.
Spark plug is in. Take off air filter so you have access to carburetor air intake. Put fresh gas in tank. Use starter spray or WD-40 as a starting accelerant. Set your choke to start engine. Spray starter fluid into carburetor opening and pull cord or push starter. The engine should fire up on the starter fluid. If engine doesn't fire, then try setting choke in different positions. If engine doesn't fire up then carburetor is suspect.
If engine fires but dies, keep spraying starter fluid into carburetor to see if you can keep it going that way ... and then move choke in different positions ... you might need extra hands for that maneuver.
If machine turns on, but dies when filter is put back, then filter might be clogged. Time for a new filter anyway.
Finally check the fuel filter and fuel line below the gas tank. It usually has a hex head bolt. Loosen bolt and see if fuel is able to fall out of tank. Loosen rubber fuel line at both ends and see if fuel is flowing. This will tell you if fuel can get to carburetor.
Usually these measures get the thing going or tell you if professional service is needed.
Sep 29, 2010 | Briggs Stratton 020273 Elite Series...
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
2,171 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
