Question about HP DeskJet F380 All-In-One Printer
Printer wont print
The printer printed a document and has not printed since
  • 564 Answers
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 26, 2009
Printer alarms us when a print job has been snet but wont print unless we manualy push the paper size on the printer
You have a mismatch paper size. Document is not same as paper you have in copier. Try printing 8 1/2 by 11 document if doesn't print check printer preferences and adjust settings. Check copier paper trays make sure don't have special settings on them
Nov 28, 2013 | Ricoh Office Equipment & Supplies
I have a hp 1300n which set's up correctly no problems when it come time to print the test page or any document for that matter it just wont print i get a print error message in my print dialog...
TURN PRINTER OFF, DISCONNECT THE USB CABLE AND RECONNECT.
INSTALL DRIVERS AGAIN AND SEARCH THE PRINTER IN THE CONTROL PANEL.
NOW "PROPIERTIES" AND "PRINT TEST PAGE".
WHEN YOU PRINT A DOCUMENT CHECK THE NAME OF THE PRINTER IN USE.
Jun 23, 2011 | HP LaserJet 1300n Printer
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Why wont it print fron microsoft wor documents
maybe your printer setting is only for internet articles.
May 02, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Printer wont print. help!!
Hi albookristin
I believe evrytime you tried to print, they all lined up in a queue for printing. If that is the case, you have to delete everything in the queue
Right click on the printer folder, look under documents, and see there are documents listed. If there are few, delete all of them. In some cases, you may have to print one at a time.
After doing all that, try to print a document. For test purposes type a one line document and try to print it.
Hope this will work for you.
Have a good day
luciana44
Nov 15, 2009 | Lexmark X2500 All-In-One Printer
I send the doc to be printed but the printer wont print it
first of all reinstall the printer driver, if it doesn't work try changing of USB cable.
Aug 13, 2009 | Epson Stylus C46 InkJet Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Printer wont print
open up the printer folder in your computer and then cancel the pending documents after that open SERVICES.MSC that u can easily find searching in your computer and after that look for print spooler restert that service 3-4 times and then restart your computer after that try and print if this oes not help leave a message i have a solution for that as well
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Printer Connected but wont print
- go to printers folder then check the status of your printer - if it is offline, right click the icon and select use printer online...
- check if there is pending documents becuase printer wont print if there is pending document in queue- to clear the pending docs. right click the icon and select cancel pending document
- printer OJ 5610 icon should be in ready status, no pending documents, and the icon has a checkmark as as default printer...
Nov 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP DeskJet F380 All-In-One Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
