Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Keeps Blowing Fuse
I have a 2004 KV36FV300 that recentantly took a power surge. I took it aparts and found the fuse had blown. I tried to replace it but the new one blown every time I plug the TV back in. Any Ideas.
    Sergeant:
    Champion:
  • 212 Answers
You obviousely have a short somewhere. Take it to a repair place.
Posted on May 26, 2009
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Massage chair will not power up after electrical surge. what could be wrong?
Depending on how much current came down the line will determine how much damage has been done, it could have blown any circuit boards or even the motor, contact your electricity provider, they are liable for any damage.
Aug 10, 2014 | Human Touch STRETCHING HT-270 ROBOTIC...
The power fuse is always blown as i keeps on changing it for the fourth time
You have a grounding issue or a short along the line. No easy way other than pulling it apart and putting a meter to it to find it.
Nov 12, 2012 | Yamaha Emx88s Powered PA Mixer System
Panasonic plasma hdtv will not power on--no blinking LED, simply no LED. Other objects plugged into same surge protector are fine; no evidence or suggestion of a power surge.
The power supply board itself maybe the main problem inside the TV. Or, it maybe something simple like a blown fuse. Replacement fuses can be found at Radio Shack or some other electronic supply store.
If it turns out the TV keeps blowing fuses, the main power supply may need to be replaced. You can find replacements at a good price at Shopjimmy.com
Sep 12, 2009 | Panasonic TH-42PX60U Television
1992 volvo 240 keeps blowing overdrive fuses
More likely that the solenoid in the transmission is shorted to ground. Has any new electronic equipment been installed recently, like stereo, alarm, etc?
Feb 10, 2009 | 1991 Volvo 240
Fuse Blowing Repeatedly
if you are not a tech have one check your tv,the voltage regulator is shorted and needs to be replace.this component can be found in the power supply.i do not have the part number and location as i have no schematic for this set.
good luck
May 03, 2008 | Televison & Video
My jvc receiver has blown fuse if i replace the fuse and it blows again what else could be blowing the fuse
blowing fuse only indicates that there is power surges in your area. in order to avoid blowing your fuse again. you may need to a have a surge supressor and auto voltage regulator used for your receiver and any appliance that may need it.
Mar 24, 2008 | Audio Players & Recorders
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
178 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
