Question about Hayward H - Series 400 Heater Top for In - Ground Pools and Spas - Dhi400
My Hayward 400 has no lights on the panel, no codes or modes
The pool goes into Spa with Filter then Gas, all works, but the Gas. Went to look and there are no lights on the panel.
  • rwt08 May 11, 2010
    Is the electricla on and is the gas valve open is the service light on
  • 27 Answers
When cycling through the modes you have pool, spa and standby and a service light. When in pool mode watch for an IF reading the main cause of problems is a corroded bad thermistor found in the inlet/outlet header closest to inlet pipehas two smaller wires on it and unthreads out to replace
Posted on Jul 20, 2009
  • rwt08 Jul 21, 2009
    There must be no power to the heater or the transformer is bad you have to test it
Hayward Heater H series 400 BTU will not start
This is a normal display when heater is being controlled by a remote thermostat. No service is required. If heater is not being controlled by remote thermostat, change setting by using the MODE key to put the heater into STANDBY. Press and hold the DOWN key and then press and hold the MODE key. HOLD down both keys for 3 seconds until the indication "bo" is removed from the display.
The key to this is DOWN first and then together with MODE, both for 3 seconds.
Make sure the display is not showing "BD".
Jul 06, 2017 | Hayward H Series Pool & Spa Heater 400k...
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
I have a hayward 400idl heater that is stuck in stand by mode. any ideas?
Hi
If you have a auto control system like a Aqualink,Aqualogic Put the controller in service than select heat. Check and make sure the service light is not on also. What happens when you press the mode button. If nothing and the button membrain looks good. open the front panel there is a ribbon cable that goes to the display and plugs into a control board in the back. Unplug the cable and plug it back in "Be Careful The Pins bend very easyly. Try the mode button again. Is there any error codes on the display?
Jan 07, 2011 | Hayward H-series Electronic Gas Pool...
My pool and spa heater is not working diplays service codes bo and AO
MAKE SURE THE FILTER IS CLEAN THAN THE TEMPETURE SENSOR MAY BE BAD, CLEAN THE FILTER FIRST
Oct 10, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward Colorlogic Light flashes like a strobe
OK I GUESS U HAVE A AUTHOMATIC CONTROL CHECK T RELAY FOR 120 V THAN CHECK FOR V AT THE JUCTION BOX IF V LIGHT MUST BE REPLACE.
Jul 07, 2009 | Hayward 12v LED Color Logic Pool Light...
HAyward H series gas heater 2500i
There is a thermistor temperature sensor beside the inlet union on the heater that goes bad, it looks line a stainless steel nut with wires on it. You can unthread to replace it and it plugs into the board behind the display. The LO means low pressure probably caused by pressure switch adjustment.
Jul 07, 2009 | Hayward Pool Products Hayward 200k Ng H...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Jun 06, 2009 | Hayward H Series Pool & Spa Heater...
Hayward H - Series 400 Heater Top for In - Ground Pools and Spas - Dhi400 Logo
193 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
