Question about Goodman CLJ30AR32 Air Conditioner
A/C comes on but fan inside does not --- Help!
Problem- A/C comes on but fan inside does not. You can feel the cold air coming out from the bottom of the a/c but fan is not comming on at the same time to. It's selective and doesn't happen all the time....sometimes the fan kicks on like its supposed to and works fine.
Over the last couple of days it's happend more frequently. When I switch the fan setting to "on" the fan comes on - but not on auto like its supposed to. Any help ??? is this a capacitor issue , voltage issue , relay or something else???
  • mike_lassite May 27, 2009
    Thanks Guys for your answers... I will look into both comments. I purchased the Cap befor I posted on this forum just because it seemed like a possible solution and it didn't cost me much(15$) .
    Question - what/ where is the transformer?
  • Your an idot May 11, 2010
    goodmans are know for relay failure, but it could be several things, intermittent motor failure, low voltage short (if so say goodbye to your transformer soon), capacitor is low more than 10% off its rating, or bad stat, need more data to give you a direct answer. give me the capacitors reading in micro farrats and we can go from there.
  • 148 Answers
Check thermostat not capacitor if it works in the on position then it should work in auto
Posted on May 26, 2009
Fan on unit comes on but no cold air comes from the registers
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
Jun 18, 2014 | Goodman Heating & Cooling
Can feel cold air coming out of bottom of freezer but it is not cold inside
Do you see ice buildup on the back of the freezer wall about half way down?
Dec 28, 2013 | Whirlpool GS6NBEXR Side by Side...
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
Came home today and the AC will not come back on. The out side unit is working, but the blower inside will not come on. Also the light on the control board will not light up at all. Does anyone hav
turn off power to indoor unit feel the fan motor if hot and turns rough bad if hot and turns smoth then most likley capacitor if cold check 5 amp fuse on the board jump red stat wire to green if no fan relay bad if fan stat bad hope this helps
Jun 03, 2009 | Goodman CLJ30AR32 Air Conditioner
Fridge warm at top cold at bottom
If the fan is no coming on inside the freezer this will need to be fixed soon. Both fans upper and lower must run while compressor runs. Inside the fresh food compartment close the damper on bottom left side next to the paned drawer. If this does not help send more cold air to the top let me know as there could be something else causing the dampers not to open and close properly.
Thanks, Sea Breeze
May 28, 2009 | GE Refrigerators
Wont get cold
check to see if there is excessive frost build up inside of the freezer on the back panel. If so you may have a defrost problem or your fan motor in the freezer may be bad. Open the drawer to the freezer and see if the fan comes on when you push the light switch. What brand is this unit?
Apr 01, 2009 | Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Goodman CLJ30AR32 Air Conditioner Logo
172 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
