Question about Sony PlayStation Portable (PSP) Console
Psp screen is black
I'm not sure what the problem is, but whenever I turn on my PSP the screen stays black and then cuts off within 5 seconds. I never dropped it.
    Guru:
  • 134 Answers
Can you go to "Recovery Mode"..? >> Hold R(right) button while turn on ur psp. if yes, You need the Pandora's battery to downgrade psp back to 1.50, its will clear a bug in flash1 on psp.
Posted on Oct 29, 2007
SOURCE:
Well i waz installing an update and i took the ac charger out and all of a sudden it froze and not when i try to cut my psp go on the light cme on green but the screen stays black and it can charge
It clearly says on the downloading screen that you must not turn off the PSP, disconnect the AC charger (if connected), or put the PSP in sleep mode. Pretty much leave it alone when you download it. To reset the PSP, you can take out the battery and put it back in and it should work again. Then re-download the update.
Aug 03, 2011 | Sony - Go for PSP
When i try to run a iso/cso game, the white psp would shoe up and then the screen truns black went back to the psp menu and it said Game could not start 80020148 my psp's system software is 5.00 M33-4
What you need to do is disable the umd from within the custom firmware menu. Completely turn off the PSP (hold the power button up until it turns off). Then while holding the right shoulder button, turn the PSP on. The recovery menu will load. Select configuration and then disable the "no umd" option. Exit from the recovery menu and insert a umd disc into the PSP. Make sure auto start is also disabled in the PSP menu settings. You should now be able to run your game.
Hope this helps and thank you for using FixYa
Jan 06, 2011 | Sony PlayStation Portable (PSP) Console
Psp battery and screen
It's bricked. What that means is that the system software has been corrupted. The most common reason for this is if someone turns the PSP off in the middle of a system update. It can be fixed, but it requires special equipment which costs about $40 if you can find it online. The following website can rebuild the system software for you for $30. They also do other PSP repairs -- you can send them both and they will check them out for you! No charge for an estimate!
http://www.richspsxparts.com/forms/pspunbrick.htm
May 28, 2010 | Sony PSP (Piano Black)
My PSP Slim will not stay turned on. The power light will stay on about 20 seconds, then it turns itself off. There is never anything displayed on the screen in those 20 seconds.
Sounds like your PSP is bricked. What this means is that the system software is corrupted, therefore the PSP is as good as a brick but fear not!
The following website can un-brick the system (reload the system software) onto the PSP for $29!
Oct 17, 2009 | Sony Video Game Consoles & Games
Jay
Try it without the battery hooked up and only the Ac Adapter hooked up.
If the psp still cuts out after 3-5 seconds then that means its a problem with the main board.
If the psp doesn't cut out then that means the battery is either bad or to much power is drained out of it and needs to be recharged fully.
You also can still try to try a different ac adapter just to be sure if the cord is to tangled up cause tangled up wires can cause the wires to break inside of the rubber casing.
Jun 28, 2009 | Sony PlayStation Portable (PSP) Console
My PSP won't turn on
Maybe your psp was bricked. Try to revive it with pandora battery and magic memory stick.
Jun 20, 2009 | Sony PlayStation Portable (PSP) Console
The screen is black,
Sometimes the PSP's will freeze for one reason or another. In most cases the psp will turn off within a minute and then restart itself. If not disconnect any power supply and remove the battery for a moment to manually reset it. Hopefully you saved recently.
Feb 21, 2009 | Namco...
Psp screen stays black
i think your graphic card or motherboard has been broken, try to get a replacement
Jan 26, 2009 | Sony PlayStation Portable (PSP) Console
Psp
your PSP is bricked. did you try updatingit and the battery fell out? if so, you bricked it. ill exchange you one, if you send me your PSP ill replace it with one of mine. please contact me if your intrested 347.468.6720
Jun 03, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
147 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
