Question about GE Spectra JBP78 Electric Kitchen Range
Clock and light in oven work but stove and burners will not
Clock and light work but stove top and oven will not heat up at all please help
  • sdav404 May 26, 2009
    thank you
    Problem Solver:
  • 15 Answers
Sounds like the wires connecting your control panel to the individual heating elements have either shorted out or been disconnected. Try taking off the control panel board and testing the connections (the four on the sides of the circuit board in the middle, and the two five pin and one three pin connector on the mainboard). If they are good, then your problem lies in the control board itself and will require a replacement from Whirlpool. Depending on if you have the touch sensor board or a push switch, it can run upwards of a few hundred bucks.
Posted on May 26, 2009
2 Suggested Answers
reg501
  • 413 Answers
SOURCE: The indicator lights and clock
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Posted on Jul 11, 2008
Stovetop & Oven not heating but clock, lights, & vent fan are working
It sounds like you are getting only one side of the power to your stove. the lights will work but no heat. your power breaker has two sides for an electric stove. It may be one side isn't reset properly. make sure that you snap the breaker completely off and then completely back on. if that doesn't work perhaps an electrician is in order or one side of your power cord has burned off at the terminal block. I have had this happen.
Apr 28, 2013 | Kitchen Ranges
Oven will not heat up
Is the gas turned on? Do the stove top burners work? Check for kink in gas hose.
Nov 11, 2012 | Ovens
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
When our family returned from out of town, we had no heat. I plugged in a small space heater close to the stove to help heat the kitchen. A bit later, I started to make toast and a breaker flipped. Flipped...
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
Apr 30, 2017 | GE JBS55 Electric Kitchen Range
Stove top or oven doesn't heats. range type is a accubake system
Have you check the outlet to see if its geting power, if not, check the main breaker in the breaker box, you may have to turn the breaker to the off postion and then back to the on postion, if power is going to the outlet your stove should work.
Feb 12, 2010 | Kitchen Ranges
My oven and stove top doesn't work
Being that I am not familiar with this particular oven/range, I can only make a suggestion. But the clock most likely runs on a different circuit, since it requires much less power to operate than do the oven and range. The heating elements are linked together, so if you have a short in a wire, or a switch that has gone bad, it could affect the entire heating system, if it was in the proper place. The best way to check would be to open the top and rear panels and inspect the wires and look for any damage. Also look for a fuse or something that may be blown. Before you do any of that, please disconnect the power from the unit. It is no fun getting shocked!
Dec 16, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
GE Spectra JBP78 Electric Kitchen Range Logo
415 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
