Question about Frigidaire ATF6000ES Front Load Washer
MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
My washer STINKS! I have four children and do a lot of laundry but I am always careful to remove items quickly and then send them along to the dryer etc. This weekend... I cam across a TERRIBLE smell -musty and damp but really WORSE. The entire load smelled - I have run the same load three times to get the "best" result I could. My sister warned me about this - but I had always been so lucky... WHAT DO I DO?
  • 89 Answers
What kind of washer?
all front load washers get this issue
the way to get rid of the smell is by doing an acid wash to your machine
set the washer to the highest temp setting (sanitize would be best)
mix in 1/2 to 2/3 cup of javex or white vinigar, either one will do it
run your washer through the longest cycle possible with no clothes in it
may need to be done more than once. and up to once a month
the smell is caused by leftover detergent and leftover fabric softner gathering on the interior shell and in the rubber boot at the door.
front load washers do not require much detergent at all, and even less fabric softner.
be careful on how much of these you are using, more is not better
this will help prevent the odor from comming back
as well when laundry is not being done, the front door should be left open a bit to allow air movement in the washer.
hope this helps
Posted on May 26, 2009
Where do I buy glisten for my washer can one Help Me And Am I at the web site
Posted on Jul 28, 2012
2 Suggested Answers
SOURCE: MY FRONT LOAD WASHER STINKS! THERE IS A MUSTY ODOR COMING FROM INSIDE.
I have the same problem with my machine. Also a frigidaire. After speaking with many repair people apparantly this is a common issue. With mine the gasket that seals around the door has separated completely from the machine and you can literally lift is away. If you pull it back you can run your finger along the metal of the machine and lift of soft black mold. I am in the midst of trying to get my machine replaced with another brand under warranty. This has actually caused severe allergic reactions to my family and took over 6 months to find.
Posted on Jul 31, 2009
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
Apr 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Switch from liquid to powder detergent, no fabric softner (I know...I love it too), clean the gasket and run a cycle with bleach only. Leave the door open whenever possible. This fixed my smelly washer, now if it would only spin!
Jun 02, 2009 | Frigidaire ATF6000ES Front Load Washer
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Laundry stinks
I find that the dryer does not dry the clothes enough. The washer can take a lot of laundry at one time but the dryer is not able to handle the load. The stink usually comes from a bit of moisture left in the the clothes, especially the towels. Break down your dryer loads or dry them on a timed cycle for a longer time.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Laundry
Interesting article explaining the problem associated with Front Loader Washing Machines and new products to combat the mold/fungus build up inside them.. Check it out....------------------------------------------------------------
Consumers who own front-loading washing machines should use only about one-quarter of the recommended amount of high-efficiency, or HE, low-sudsing detergent. Standard, non-HE detergents in front-loaders are too sudsy.
Why don't top-loading machines have this problem? Less efficient top-loaders that use more water typically flush out excess suds, soil, detergent and fabric softener.
Class-action lawsuits against manufacturers such as LG, Whirlpool and
Maytag have been filed, alleging mold and mildew problems in front-loading washers.
Some suits have been settled while others are pending, affecting hundreds of thousands of consumers, said Rob Shelquist, a partner at the Lockridge Grindal Nauen firm in Minneapolis.
According to Whirlpool, the low water use and airtight seals on HE front-loaders create the potential for odor-causing mold and mildew. Whirlpool has its own anti-odor product, Affresh, which sells for $7 for three treatments. SmellyWasher is more expensive than Affresh initially ($16 for 24 treatments), but Flynn's product lasts a year.
SmellyWasher can be used as a preventive monthly or less often if smaller amounts of detergent are used. Affresh is also used monthly, but a $7 packet of three tablets lasts only three months. Flynn's product will remove musty odors from towels or clothing, which Affresh does not claim to do.
Getting rid of problem
To eliminate odors, Smellywasher users should put a capful of Flynn's product in the detergent dispenser, select the hottest water temperature and the extra-large load to fill the empty washer with the largest amount of water. Let the water agitation start and then stop the washer and allow the solution to soak for two to four hours. Repeat as necessary and allow to soak overnight if needed.
Flynn said that the product works best in hot water. Consumers might want to run the faucet closest to the washing machine until the water is hot before starting the process or turn up their water heater temperature until the load is finished. (Remember to turn the temp back down to avoid scalding.) Flynn offers a money-back guarantee. Stubborn cases of mold and mildew might require five to seven treatments.
Susie Thymian is such a believer that she now sells SmellyWasher in her own store, McGinnis Appliance in Morris, Minn. Thymian had blamed the musty smell from her towels on her teenagers, who often leave wet towels in a pile in their bedrooms. Her kids' solution to the stink was to use more towels. Thymian's answer was to use more bleach in the laundry, but nothing got rid of the mystery mold odor until she found Flynn's product.
Only a few of Flynn's customers are from
Minnesota so far. Most come from regions with higher humidity. Sharon Turner, who lives in steamy San Antonio, said SmellyWasher worked after several cycles. "I was ready to throw out my plush towels and my front washer. It saved my sanity."
Link to this article..http://www.chicagotribune.com/business/chi-smelly-washer_chomes_0912sep12,0,7369054.story
Sep 14, 2008 | Bosch Axxis WFL 2060 Front Load Washer
GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Sep 13, 2008 | GE Energy Star WCVH6260F Front Load Washer
Musty odor in laundry
I would say that you are getting a build up of soap and oil from our bodies, on the inside of your wash bowl.
The Tubs pull out of the washing machine really easy and then you can water blast the two tubs.Solves this problem?
Once you learn how to pull the tub out you can also clear a blocked pump.
I have a after market lint filter fitted to my F&P washing machine,works wonders .
ask your local whiteware Man for some hints on a Bowl removal.
A five minute job???
Jul 27, 2008 | Fisher Paykel EcoSmart GWL15
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
459 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
