Question about Dryers
Kenmore 110.67867100 dryer
i just need to get inside my dryer, and don't want to break anything doing it.  i've never been inside this one, and just need to know where the tabs that hold the front or top on, and where to pry to get it open.  thank you for your time.   ken b.
  • 291 Answers
You Need to take out 2 screws  on top where your lint filter goes  take a putty knife and slide few ins. for end tell ya feel it hit the clips then just push in on the center of the clips while pulling up slightly on the top
Posted on Oct 21, 2007
    Problem Solver:
  • 11 Answers
Try pushing in a flat screwdriver about 4" from the left edge and right edge on the top lid.  If you can open up a small crack under the lid  (again with a screwdriver) you will be able to see the two clips.  Each about 1" wide and you would push them straight back about 1/4 to 1/2 " to disconnect them from the socket.  For reassembly, just align the lid , then press it down to snap both of the tabs into place.
good luck,
paul
I have a kenmore 80 series dryer. 18 years old. Makes loud buzz when starting and overheats and stops in about ten minutes. I've bypassed thermal fuse and samething happens. I've also cleaned out...
You don't want to bypass the thermal-cutoff. If the thermostat is malfunctioning, it WILL overheat and cause a fire!! For the age of it, I would replace the whole dryer! It's going to cost you more in time than the value of the unit.
May 21, 2012 | Kenmore Dryers
I need to know how to light the pilot on my kenmore dryer
What is the model number of your dryer? The number may be located inside the dryer door.
Dec 18, 2011 | Kenmore Dryers
Switch_bypass to dryer door
You will have to take apart the dryer. First UNPLUG IT from the wall. Then pry up the top, gently - it is pressed on with plastic push screws. The top should fold all the way backwards, have something to support it so it doesn't break off. You should be able to see the switch now close to the top, inside the dryer. Unplug both wires then connect them. You can either electrical tape them together or hard wire them. Be sure the wires do not dangle too low as to touch anything. Tape up all connections on the wires. Replace the top, plug in and it should work.
Oct 21, 2011 | Kenmore 62602 Electric Dryer
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
We have a front load Kenmore dryer that is about 10 years old. Its model number is Mod 110.62994102. Our dryer takes forever to dry clothes. We have cleaned out the vent in back as well as the exhaust...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
The dryer has power but when I press start it won't do anything. I've unplugged it and replugged it. I've cleaned the lint out.
heatman101
Jul 11, 2011 | LG Dryers
Hello, i have a Kenmore series 80. It will not run with a load inside, only empty??? Anyone?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Dec 29, 2010 | Kenmore 77632 Gas Dryer
Manchine is getting power light works on the inside but nothing happening, can't hear anything when pushing the power button it's a kenmore 80 series model 110.67832791 any suggestion on what could be...
heatman101
Oct 16, 2010 | Kenmore 63942 Dryer
My dryer won't turn on (start button?) The timer works though. It quit working in the middle of a cycle and I'm pretty sure the heat was still working, it just stopped working.
Sound`s like a broken drum belt. When the belt break`s on most kenmore/whirlpool dryer`s it prevent`s the unit from starting via a ``kill switch`` located under or next to the belt tensioner/idler pulley.
Since you`ve indicated the timer appear`s to advance/work, it is not the thermal fuse/cut-out.
The other possible fault is in the start button, but that is not very common.
I`d look at the belt. That`s what I`d check first. Hope that help`s.
Good luck and thank`s for visiting fixya.
macmarkus :)
Dec 13, 2009 | Kenmore Dryers
Coins stuck inside dryer fins
raise the top and there are 2 1/4 screws running into each fin ,,,,, take screws out and dump fin and that wit do it for you / larryyb
Nov 30, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
Marvin
Marvin
