Question about Toshiba Satellite A60 Notebook
Having trouble getting securing strip round hinge
Toshiba A60 fitted new cable to screen but am having difficulty getting security strip over top of hinge in order to re fit.
Any ideas appreciated
Cheers
How do you fix a dm4 Hinge that is broke where it connects to the screen
You can buy hinges on ebay at:
http://www.ebay.com
Just type your computer make and model in the search followed by lcd hinges.
If the hinges are broken where the lcd screen connects to the base of the laptop then you will have to remove the screws from the bottom of the laptop and remove the strip that is at the top of the keyboard to get to them.
If the hinges on the side of the lcd frame is broken then you will have to remove the plastic strip that is around the lcd screen. Remove the plastic or rubber bumpers on the plastic strip then you will see screws to remove to remove the plastic strip. Then you will see hinges and screws on the side of the lcd screen that you can remove. Once you have them removed you can lean the lcd lid forward so that it drops in your hand. Don't let it drop on the keyboard, just into your hand and not too far because there is a cable on the back of the lcd that you don't want to damage. The cable can be taken loose from from the lcd at the back near the top if you like. Sometimes there might be a piece of tape securing it. If the lcd screen does not come out then there are screws on the 4 corners that is securing it and the hinges.
May 13, 2012 | Computers & Internet
Tip
How to repair Hinges on a HP ZV6000
<p>If a loose screen hinge screws <br /> <p>1. Turn off your computer and remove all components of the computer that sending an electrical current to the system, including power cables, peripherals and battery. <br /> <p><br /> <p>2. Close the display and turn off the computer base to cope with the hinge side of the computer to you. <br /> <p><br /> <p>3. Extract the four screws on the bottom border. <br /> <p><br /> <p>4. Remove the rubber plugs on the back of the hinges of the screen and the two screws underneath them. <br /> <p><br /> <p>5. Turn off the computer and open the screen, so they sit flat against your work. <br /> <p><br /> <p>6. Press the area marked on the right side of the keyboard cover (the plastic strip on the top of the keyboard) to it from the computer. Lift your right a little push and cover the central part of the keyboard to release it. Lift up the middle and let the left up to the keyboard cover for free from the computer. <br /> <p><br /> <p>7. Unzip, the four screws on the top of the keyboard and the keyboard on the fold of the palm rest with the buttons down. Disconnect the keyboard cable and remove the keyboard. <br /> <p><br /> <p>8. Loosen the two screws that secure each display hinge to the computer. <br /> <p><br /> <p>9. Attach the keyboard and the keyboard. Make sure all screws that secure each part to fix. <br /> <p><br /> <p>10. Place the screws on the back of the hinges of the screen and replace the rubber stopper. <br /> <p><br /> <p>11. Insert the battery, cables and components that you removed in step 1 to complete the process. <br /> <p><br /> <p>Broken so replace hinges <br /> <p>1. Turn off the computer and get rid of its power transmission components. <br /> <p><br /> <p>2. Turn off your computer and remove the four screws on the hinge side of the base of the keyboard. <br /> <p><br /> <p>3. Remove the rubber plugs on the back of each screen hinge, and pull the two screws in the hinges. <br /> <p><br /> <p>4. Unplug the computer and open the screen. Follow the instructions to step 6 of chapter 1 to the keyboard cover. <br /> <p><br /> <p>5. Remove the keyboard by following step 7 of Section 1 <br /> <p><br /> <p>6. Disconnect the cable from the connector on the computer screen right in the middle of the screen panel. <br /> <p><br /> <p>7. Disconnect and remove the two antenna cables from the mini-PCI wireless card in the middle left of the keyboard and cables in the guide, take it to the computer. <br /> <p><br /> <p>8. Unzip the two screws on each hinge and lift the computer screen. <br /> <p><br /> <p>9. Remove the six rubber pads on the front panel display, and remove the screws under them. <br /> <p><br /> <p>10. Remove the display. <br /> <p><br /> <p>11. Unzip the two screws on each screen, internal hinges and remove the hinges of the screen. <br /> <p><br /> <p>12. Follow the procedure in reverse, with hinges to the new computer installation. Make sure you remove all the screws, so everything is nice and tight as the computer is assembled. <br />
on Jun 22, 2011 | Computers & Internet
MBP screen hinge tightening
Hinges are located under the lcd screen and go into the bottom of the base or palmrest. You'll need to remove the strip that is right above the keyboard that normally houses the power button on most laptops. The strip might be secured by screws that are on the bottom of the laptop. Be careful removing the strip, most times there is a cable attached to it under the bottom. Once the strip is removed the hinges are exposed. Just take a phillips head screw driver and tighten them.
Mar 27, 2012 | Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Vertical lines on a screen
If the image is ok on an external monitor it
Could be a failing screen, or loose VGA cable
Remove the screen bezel and the hinges that hold the screen onto the lid, check that the vga cable is tight in the connector, check also that the inverter cable is secure and the lead from the motherboard to the other end of the inverter cable is tight.
Check if possible that the other end of the vga cable that goes to the motherboard has not worked loose.
If these are tight, the screen is beginning to fail and will need replacing
If you get the same problem on another external monitor, the problem lies in the graphics chip, sometimes , this is a sign of overheating, you should strip the laptop and clean out the fan and heatsink assembly
Jul 28, 2011 | Toshiba Computers & Internet
Need to replace cpu fan on Toshiba Satellite A85-S107 and can not get the laptop appart.
Remove the battery, unplug the unit.
  • Take off the hard drive cover by extracting the two screws that secure it and then taking it off. Take out the screw on the modem and wireless card cover and take the cover off. To remove the hard drive, shift it to the left to disconnect it from the motherboard and pull it out of the computer. Gently disconnect the Wi-Fi card antenna cables and take out the card. Extract the screws on the modem card, disconnect it from the motherboard, and then disconnect the cable to free it from the computer. Remove the optical drive screw, push the drive out of the laptop and then take it off. Extract the 15 screws out of the bottom of the laptop and turn the laptop over.
  • Open the laptop and fold back the LCD screen as far back as possible. Pry up the keyboard bezel (the plastic strip above the keyboard) by inserting a flat-head screwdriver or a spudger in the groove at the right side of the strip. Pull the bezel off the laptop. Extract the keyboard screws and fold the keyboard down over the palm rest. Release the flat cable that connects the keyboard to the motherboard and take the keyboard off the laptop. Remove the screws securing the LCD screen to the back side of the laptop. Disconnect the video cable and the Wi-Fi cable from the motherboard and remove the screws on the LCD screen hinges and then pull the screen off the laptop. There are four visible cables that are connected to the motherboard: the switchboard cable, the speaker cable and the touchpad cable. Disconnect all three. Take out the four screws from the top cover and pry the top cover off by running the flat-head screwdriver along the groove around the entire laptop and pulling it off. Now the laptop is completely disassembled to where the motherboard is exposed as the last remaining component.
May 05, 2011 | Toshiba Satellite A85-S107 Notebook
I own an acer 10.1"
it isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
1063_66_99.jpg Remove the Camera Board from the LCD Module.
  1. Remove the four securing screws (two each side) from the LCD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
  1. Remove the adhesive strips holding the MIC cable in place.
1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
  1. Remove the adhesive strips holding the Camera cable in place.
  2. Remove the Camera cable from the LCD Module.
  1. Remove the adhesive strips holding the Antenna cables in place.
1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
Apr 05, 2011 | Computers & Internet
How do you remove the keyboard to replace it with a new one
Removing the Keyboard
To remove the keyboard, first remove the battery pack, then follow the steps below.
1. Open the display panel.
2. Insert a thin tool into each of the narrow holes in the strip cover and lever the strip cover up to release its latches.
3. Remove two M2.5×3 silver screws securing the keyboard.
4. Lift the keyboard out and place over the display hinges, revealing the keyboard cable.
5. Disconnect the keyboard cable and remove the keyboard.
Below is the link for your service manual for future refernce. It is free to copy, print and use.
http://tim.id.au/laptops/toshiba/satellite%20p20-25.pdf
Nov 19, 2009 | Toshiba Satellite P25-S507 Notebook
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
Toshiba Satellite A60 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
