Question about AEG Santo 3888 KG8 Bottom Freezer Refrigerator
Flashing temperature lights
Aeg santo 3774-6KA temperature cannot be determined
SOURCE:
BIKER T
  • 909 Answers
SOURCE: AEG Santo 3778-8 KA Temperature Problem
hi tracy, think its possibly better getting a repair guy in as this fault is not streight forward. possibly a fault in the defrost circuit, or freezer fan not functioning, or possibly a leak in the system. all theese areas need testing equiptment.
Posted on Sep 20, 2007
kweaver1
  • 3 Answers
SOURCE: AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Posted on Jan 20, 2008
KikkaMikko
SOURCE: AEG Santo Fridge light flashing
Here is fix photos:
http://www.elisanet.fi/mtj/santo/AEG-Santo-fix.html
Posted on Aug 11, 2008
SOURCE: AEG Santo 1683-TK7 Led's and
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Posted on Apr 10, 2010
potek18
  • 528 Answers
SOURCE: AEG Santos S83168KD1 - The
Hi there. Here are few tips on how to reset AEG refrigerators
Control Panel (water dispenser) I J N M O K L I. Yellow indicator lamp Lights up when the locking function has been activated. J. Button for carbonated water. - Used for the choice of carbonated water. - For the engagement and disengagement of the locking function. K. Button for ordinary water. - Used for the choice of ordinary water. - Switches the background lighting on and off. - Switches off the indicator lamp for water filter replacement. L. Yellow indicator lamp Lights up when the water filter must be changed. M. Water out-feed Activated when a glass or something similar is pressed upwards against the flap. N. Flap O. Lighting AEG/Electrolux 8183969-01/6 9 The functions of the water dispenser The locking function: The locking function is activated by the production plant. For temporary unlocking: Keep the button (J) pressed in for about three seconds until the yellow indicator lamp (I) goes out. The locking function is re-activated automatically after about three seconds. For permanent unlocking: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. The button (J) or (K) lights up to indicate unlocking. To activate the locking function: Keep the buttons (J) and (K) pressed in at the same time for about three seconds. Activation is indicated by the yellow indicator lamp (I) lighting up.
Click the link i have provided to you for the service manula of your refrigerator. Scroll down and look at the right side then copy all document on the text box then paste it to microsoft word. Please click here for the manual.
Posted on Jun 22, 2010
Aeg santo fridge keeps freezing
Fixya will not let me post links today, or their "capcha" thing does not seem to be working properly, so I will have to try this another way.
I've done some research on your issue and it seems that should only happen if the temperature sensor goes bad, or the evaporator sensor. Each of the two parts cost less than 30 pounds each, so may be less expensive than tossing out the whole thing.
Try browsing to shop (dot) aeg (dot) co (dot) uk
Then in the search at the top right, type in "santo" and look for the two sensors and decide if it would be worth a try.
Oct 14, 2013 | Refrigerators
How do i set my temperature on my fridge freezer its a aeg santo ?
Hi
The santo was originally built with a standard thermostat, this is graduated from 1 to 6 where 1 is the warmest setting and 6 is the coldest, normally you would set this to btween 3 and 4 and adjust it slightly to your favourite.
Regards
Gordon
Apr 20, 2011 | Refrigerators
Aeg santo 1688 fridge power/light flashes when door open
Check if the bulb is loose in its socket, you may be able to twist it to tighten it, turn off the power first though.
Oct 13, 2008 | AEG Refrigerators
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
Oct 06, 2008 | AEG Refrigerators
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
Sep 19, 2007 | AEG Santo 7085 KG Side by Side...
What does the flashing (warning?) light mean
Did you ever get any advice for this problem? Please repost if not.
Oct 22, 2006 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 3888 KG8 Bottom Freezer Refrigerator Logo
55 people viewed this question
Top AEG Refrigerators Experts
Tony
Level 1 Expert
David Del Polito
David Del Polito
Level 1 Expert
Steve F
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
