Question about Frigidaire FMV145K Microwave Oven
Does not heat up food
Microwave power and lights every thing works. but, does not heat up food
  • 3,037 Answers
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on May 26, 2009
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
Microwave lights up, turntable turns and fans run however food does not heat up. I have checked to ensure the power level is up which it is. Tried the express 1 minute as well as using the time mode and...
The problem is one of three things, the magnetron "common issue" the high voltage capacitor and diode can be a factor, all three work together in conjunction with the high voltage transformer to generate the high voltage that heats the food.
Mar 05, 2011 | GE JVM1850 1000 Watts Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
Viking 1100 watt Microwave will not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fjj
Jan 05, 2010 | Viking VMOC205SS Microwave Oven
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
275 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
