Question about Waterway Above Ground Hi Flo Pump
Pump hums then blows circuit
Changed sand in waterway 22" filter. cleaned and put back all parts. plugged in, opump hummed for about 10 seconds then blew fuse. tried again, same results. thanks, kathy
  • kdinardo602 May 26, 2009
    Not yet, but will definitely be checking into the capacitor! Thanks, Kathy
Start capacitor is probably bad
Posted on May 26, 2009
Waterway pool pump is humming but fan is not turning
Shorted motor windings, can you move the turbine when turned on or does it feel like it is being held in place. WARNING!!! do not try with your hand, use a tool. Possible capacitor, but I would suspect motor to turn slowly.
Apr 02, 2013 | Waterway Pool & Spa
Why is sand shooting back into pool
Inside the sand filter there are laterals that are PVC pipes with many narrow slots along their length. If a lateral is broken then sand will not be stopped by the lateral. Another possibility is that the part these laterals screw into is broken and sand leaks through. I hope this helps.
Aug 07, 2011 | Waterway 22" Swimming Pool Sand Filter W15...
We have a clearwater sand filter system and when we turned it on the sand started into the pool. What did we do wrong?
you most likey reversed the wires or you hooked up the sand filter pipes backwards try reversing the pipes on the pump first. If that does not work try reversing the wires, however you will have to flush the pump before using again or you will damage the pump
Jul 07, 2010 | Waterway Clear Water 22" Sand Filter...
Our hot tub uses a Waterway Pump. We emptied the water and refilled it with clean water. The pump now just hums... and doesn't pump. Did we do something wrong? Is there a solution. It is 220V. The...
Was the pump working prior to the cleaning or had it been sitting dormant? The motor relies on a starting circuit within it to operate. One of the components can be bad or the pump can be siezed up.
Turn off the power and remove the back cover from the motor. Try to turn the shaft by hand. Is it free to turn? If so, the problem is inside the motor. If not, look for the obstrction.
A local electric motor repair shop can help you if you find damage in the motor and/or pump.
Dec 27, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Plug in motor and it hums for 10 seconds then the breaker trips. Why won't it rotate?
The shaft is frozen; you've got damaged goods. Your only option is to replace the motor.
Jul 19, 2009 | ADVANTAGE 1.0 Hp 1 Speed Waterway Spa Pump...
Motor humming but not engaging
The pump needs to be primed by adding water to the basket.If it still doesnt start it might need the a rebuild which usually involves replacing the bearings(cost about $150.00 NJ area).
Apr 22, 2009 | Hayward S220t Top Mount Pro Series Sand...
Waterway Above Ground Hi Flo Pump Logo
428 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
