Question about Sony FD Trinitron WEGA KV-32HS500 32" TV
SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
FEW DAYS BACK EARLY MONRNING WHEN I PUT ON MY TV, IT JUST FLASHED AND PICTURE GONE BUT SOUND IS THERE & CAN CHANGE CHANNELS, ONLYTHE STANDBY LIGHT FLASHING... STILL WE WERE KEEP ON PUTING IT ON TO HEAR THE AUDIO SUDDENLY THE PICTURE CAME A FEW DAYS LATER, THEN AGAIN WHEN WE RE-STARTED THE SAME PROBLEM, AFTER A FEW DAYS THE THIRD TIME THE PICTURE CAME AGAIN ... AGAIN WHEN WE RE-START THE PICTURE NOT COMING ONLY THE STANDBY LIGHT FLASHING
 CAN ANYONE HELP US GIVING AANY IDEA ABOUT THIS WHETHER IT IS WORTH TO REPAIR OR THROW IT AS SCRAP ??
  • candace_bran Jul 17, 2008
    picture was fine & sound we had to move the t.v which every heavy so it got juggled a little we turned it on worked for a few momentand the picture went out but sound was on , could change channels . TV only 13 -14 years olds
    help
The fault seems to be a fault in the line out put stage.
check connections in output stage. for poor joints.
Posted on Aug 16, 2008
I have the exact same problem! I'm assuming it's time for a new tv.
Posted on Oct 25, 2007
I turn my sony trinitron off. when turn it back on it will not turn it will not come on for hours and sometimes a couple of a couple of days!
I HOPE AFTER FEW MINS OR HOURS OR DAYS when your TV gets on & picture comes then everything works normally atleast for few mins...then following is the situation.......after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....it takes few mins ( in your case few hrs or days ---- very rare case ) for picture to appear...........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching TV ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around US $ 10 & for my customers (in bangalore) i will take another US $ 12 as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact TV service engineer or sony service centre ------- because they are highly experienced & can fix this component very easily.....
Apr 21, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
No picture on tv but have sound
how many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Jan 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Apr 07, 2007 | Sony KV-27FV16 TV
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
1,240 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
