Question about HP Officejet Pro L7590 All-in-One InkJet Printer
Replacing the ink cartridge
Installed new black & yellow cartridge into my new HP7590 printer and it does not recognise that there is a new cartidge - keeps showing the same message to replace. Tried taking out & putting in again. Turning off & on. Grrr
  • 564 Answers
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Posted on May 26, 2009
After replacing cyan, magenta and yellow toners with genuine Canon toners, my Canon MFC 8180c does only use yellow color to print while trying to print or copy color stuff.
You will need to do an ink reset because from what you have explained the machine has only recognised one of the coloured inks and the black.
1. Switch on the machine and set it up for removal of all the ink cartridges . Then fully remove each of them (including the black) and then replace them back in the correct slots. Make sure they are fully home when you fit them. The machine now thinks you have removed used cartridges and replaced them with new ones.
2. Then close the printer and follow the instructions on the display window on the printer to indicate to the machine that you have replaced each ink tank with a new one.. It will ask in order if you have replaced each of the ink tanks from black onwards and the answer has to be yes. Make sure you hit the correct buttons when responding because if you do not the printer will not recognise the presence of that particular ink cartridge (and will not use it) which I believe is part of the problem you have now.. Check your user manual to make sure you are pressing the all the correct keys for your model machine.
Hope this helps some.
Dec 30, 2015 | Canon Office Equipment & Supplies
Why does my printer not recognise ink cartridges
there is a reset for that that comes with some carts or you can just order the reset mabye
Jul 25, 2014 | Cannon Office Equipment & Supplies
I use 3rd party ink and why my color ink light up at my printer pixma mp 287
This will either be because your printer is having trouble recognising the cartridges or warning of low ink because the cartridges have been refilled. Connect a computer to the printer and it will hopefully give you more info.
If your printer cannot recognise the cartridges try wiping the contacts on the front of the cartridges and re-installing. If your printer still doesn't recognise the ink cartridges then sadly they will need replacing.
If it is just a low ink warning then carry on printing untill the printer thinks the cartridges are empty and prevents you from printing. You can them get around this message by pressing the stop/reset/resume button for 5 seconds and continue printing. More information on this can be found here: http://www.refreshcartridges.co.uk/igloo/the-infamous-canon-resumestopreset-button/
Hope this helps.
Feb 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
On my HP Business Inkjet 1200 the black/magenta/yellow lights are flashing but not the cyan. Neither the printhead or ink cartridge light is lit. With 3 out of 4 lights lit what is the printer complaining...
You may be using non original ink catridges, the printer chip will not recognise so flashes as if needs replacing.if refills are original printer chip may need to be reset.
Feb 03, 2018 | HP Business Inkjet 1200dtn Printer
Canon mp145 cartridge not recognised after
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-1
Aug 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Installing new ink cartridges
Be sure you have snap the ink cartridge tight, and check the expiration date of the ink cartridge.
Nov 12, 2008 | Dell Office Equipment & Supplies
Canon pixma ip 4200 printer problems
in the printer driver there is a option that whenever you install a new cartridge it has to be reset otherwise it shows the message the above you quoted. one more option is there that is change the chip of yellow cartridge and black, after doing this please whip circuits of the cartridge and printer carriage block before installing the cartridge
Apr 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
