Repair stove toyostove wont start
  • amigoe Oct 21, 2007
    Toyostove Laser 30 has error code EE 22 and won't start or ignite. any solutions?
  • 625 Answers
Is the toyostove propane or kerosene?
Posted on Nov 04, 2007
On l-56 stove an error code EE 8. what is this and can it be repaired?
The blower motor is not working properly. Turn the stove off and remove the front cover. Remove the lower baffle in the front. Remove the black hose that is about 1 1/2" in dia. If it breaks don't be surprised. Stick a pencil in the hole and spin the fan. Keep trying until it spins freely. If it spins freely from the start the motor is burned. Put the black hose back on and try to start. IF the hose broke you will need a new one. For now put some electrical tape around the break to get you going.
Keep us posted.
Tom
Oct 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a toyostove laser 30 and it leaks at the bottom (there is no parts or stove damage) and it does not burn cleanly. I will smell terrible oil fumes after every heating cycle. What should I do? I have...
If you have a A model Laser 30 you will have to take the stove apart to get to the fuel sump pipe. 9/16 wrench will tighten it. If it's a B model you can reach it on the lower right side of the heater.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Showing ee 8 wont start
Remove the front cover. Remove the 1 1/2 inch black hose that has a 90 degree bend into the silver box. With the stove OFF stick your finger in the hole and try to spin the fan. It may take a few times but keep trying it should break free. Once free the stove will work. If it spins freely and still gives the EE8 you wll need a new motor.
Tom
Sep 18, 2010 | Rinnai Toyostove Direct Vent Heater:...
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
Tom
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Lost manual stove is blinking code ee2
No ignition. Check the igniter by feeling around the two red wires when you try to start the stove. They will get very hot so be careful. If the igniter gets hot you have a fuel problem. No fuel, low fuel or dirty filter.
Keep us posted,
Tom
May 10, 2010 | Rinnai Toyostove Direct Vent Heater:...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
L60AT wont relight
EE2 means no ignition. It could be No fuel or low fuel, dirty filter. You need to look at the flame when you try to start the stove. If you have flame then the igniter is good. If there is no flame and a bumping noise you have a fuel problem. No flame and no bumping you may have an igniter problem. Feel around the burner pot to see if it gets hot. A bad igniter will lead to a flooded stove if you continue.
Tom Hawkins
Bethel, Alaska
Dec 23, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove l73
Try cleaning the fan blades, etc. Does the blower stop after a while and not start again? If there is no ignite at all, could you need to clean your stove. Especially the heat pot?
May 01, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 73
A manual can be found online by googling Toyostove 73 and owners manual or manual. I use it often. It is at on the rural energy website.
Jan 13, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
