Question about Symbol P470-SR1211100FB Handheld
Frozen. Yellow light on, Buttons appear to do nothing.
Scanner in incorrect mode, attempted reset by entering menu. Scanner froze up. I removed the battery, now the little light above the screen is yellow and the screen displays nothing. It appears to be frozen. Pressing buttons does nothing apparent. Is there a way to perform a hard reset?
    Scholar:
  • 74 Answers
Holding down the Enter key on the keypad for 30 seconds forces the scanner to reset. It is called a forced power down.
Posted on Oct 16, 2009
My apple laptops login screen keeps going on and off on and off i cant login
Try resetting the SMC
Before Resetting the SMC Try each of the following steps in this order before you reset the SMC. Test the issue after completing each troubleshooting step to determine if the issue still occurs.
  1. Press Command + Option + Escape to force quit any application that is not responding.
  2. Put your Mac to sleep by choosing the Apple () menu from the upper-left menu bar and then choosing Sleep. Wake the computer after it has gone to sleep.
  3. Restart your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Restart.
  4. Shut down your Mac by choosing the Apple () menu from the upper-left menu bar and then choosing Shut Down.
If your Mac appears to be running normally but isn't responding, force the computer to shut down by pressing and holding the power button for 10 seconds. Note: You will lose any unsaved work in any open applications.
For Mac portables experiencing issues related to the MagSafe power adapter and/or battery, try:
  1. Unplug the MagSafe power adapter from the Mac and the wall power socket for several seconds.
  2. Shutdown the Mac. Physically remove and re-insert the battery (if it's removable) and startup the Mac.
If the issue is still not resolved after following the troubleshooting items above, an SMC reset may be necessary.
After performing normal troubleshooting, these symptoms may indicate that an SMC reset may be necessary:
Fans
The computer's fans run at high speed although the computer is not experiencing heavy usage and is properly ventilated.
Lights
The keyboard backlight appears to behave incorrectly (on Mac computers that have this feature).
The Status Indicator Light (SIL) appears to behave incorrectly (on Mac computers that have an SIL).
Battery indicator lights, if present, appear to behave incorrectly (on portables that use non-removable batteries).
The display backlight doesn't respond correctly to ambient light changes on Mac computers that have this feature.
Power
The computer doesn't respond to the power button when pressed.
A portable Mac doesn't appear to respond properly when you close or open the lid.
The computer sleeps or shuts down unexpectedly.
The battery does not appear to be charging properly.
The MagSafe power adaptor LED doesn't appear to indicate the correct activity.
System Performance
The computer is running unusually slowly although it is not experiencing abnormally high CPU utilization.
Application icons may "bounce" in the Dock for an extended amount of time when launched.
Applications may not function correctly or may stop responding after being opened.
Video
A computer that supports target display mode does not switch into or out of target display mode as expected.
A computer that supports target display mode switches into or out of target display mode at unexpected times.
Oct 20, 2013 | Computers & Internet
Need to reset my Windows Vista password on an old laptop. I forgot it.
Which operating system ????....
If you forget your Windows Vista password, you can reset it quickly and safely using a password reset disk or an administrator account.
Windows Vista allows you to create several accounts for different users; however, the administrator account controls system settings and manages the entire computer.
If you forget your password, resetting it allows you to create a new one to access system files. The reset procedure involves using simple password reset wizards.
Restart your computer and wait for the logon screen to appear.
Enter an incorrect password in the Password field and wait for the "User name or password is incorrect" message to appear.
Click "OK."
Click the "Reset Password" button to start the Password Reset wizard.
Insert your password reset disc in the optical drive, or if it is an external drive, connect it to an open USB port on your computer.
Click "Next" on the password reset wizard and select the password reset disk from the list of options. Type a new password and a hint for the password.
Click "Next."
Click "Finish" to log in with the new password.
Using an Administrator Account
Log in to your administrator account if you are the computer's administrator.
Click the "Start" button, type "lusrmgr.msc" (without quotes) in the search field and press "Enter." If prompted, enter your administrator password.
Double-click "Local Users and Groups" and then click "Users."
Right-click the account belonging to the user who forgot his password and click "Set Password."
Enter a new password yourself or have the account owner enter a new password he wants to use.
Re-enter the password for confirmation.
http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
http://windows.microsoft.com/en-US/windows-vista/Create-a-password-reset-disk
or
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password
Sep 28, 2013 | Acer Brand 17.0 WXGA+ Glossy Laptop...
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
I had to launch start up repair and the battery died half way through... The laptop now says "Computer build error. File exception failed to find c:/ (etc)" and it won't turn on, just...
Step 1:
Enable VGA mode
Reboot
Feb 07, 2013 | Computers & Internet
\Windows\System32\Config\
Is there anything else on the error message ?
Enable VGA mode
Reboot
Jan 28, 2013 | HP Computers & Internet
My desktop PC won't take my password, could it be caused by bad CMOS battery? This computer has not been used for over a year.
The cmos battery holds your password and boot order settings on some motherboards removing the cmos battery will not remove password its held by a small chip which has back up power designed for this
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Hope this helps.
Jan 16, 2013 | HP Computers & Internet
Ever since I spoke to Verizon about a problem last month with my modem, I keep getting cut off line. After 5 or 10 minutes, I try to get online and get a little window with this message: Up in the...
Two resons can cause this problem
1. Loose network cable from the computer to the modem
2. Incorrect browser settings on the computer.
I guess you might have reseated the network cable coming from computer to the modem /router
In case you have not then this would be the first step to start with.
Second restart your computer and at the Dell logo screen tap F8 key a couple of times . You would get a screen windows advance options menu.Select safe mode with networking , using your arrow keys on the keyboard . Hit enter . Login as the adminstrator , try using the internet if the interent works fine in the safe mode with networking without disconenction , restart the computer and reset the browser settings.
In case you need more support , post back with the results of the steps given above
Thanks for using fixya
proton
Aug 30, 2010 | Dell Inspiron 530 Desktop Computer
Samsung LE32R74BDX 32 in......
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Oct 03, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
How to retrieve current radio code for my 2004 chevy aveo?
Here's an easier way. Purchase a 9 volt battery powered radio / computer MEMORY RETAINER. Plug into your cigarette lighter/power socket SECURELY. AFTER replaceing the battery, remove 9 volt poer feed, and BINGO. Radio stations memory, clock will all RETAIN. their memory. Hope this helps
Apr 19, 2009 | 2006 Chevrolet Aveo
Symbol P470-SR1211100FB Handheld Logo
410 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
