Question about Acer Aspire 5050-3242 Notebook
Acer 5050 blue screen
HI am trying to load win xp on acer aspire 5050 , it reaches a poitn then blue screen , i havent got the recovery disc .can you help please
  • 1,006 Answers
Problem with hdd or ram memorje!Try to put another hdd and try to format it
IF hdd is SATA it need special drivers
Posted on Oct 21, 2007
SOURCE:
When i turn on my acer aspire 5050 laptop the only thing come up on the screen is operating system missing
This is a problem that I have encountered many times, in most cases this indicates the hard drive is bad. If you have a recovery disc try to re-install your operational system, if you are successful it proves that you had corrupted files and windows could not start.
Dec 27, 2010 | Acer Aspire 5050-3242 Notebook
After installing an automatic update, upon re-starting, my computer will load the windows xp welcome screen, the blue bar, under the windows xp icon, scrolls as if the computer is booting up. The screen...
Sounds like the HAL.DLL problem that I have with my Aspire One.
Try booting off a genuine Windows XP disc and choosing the 'recovery console' option. At the command line, type 'CHKDSK C:' and press Enter. If you're lucky, that will do the trick.
Feb 07, 2010 | Acer Aspire 5050-3242 Notebook
My screen goes blank and stops just before getting to were you put in the pass word...
Are you using Window XP, Does it display the Windows logo on start up, if so try to go to safe mode by pressing F8 on start up and select "Last know good configuration that worked" when option displays, and if it again it stucks then insert the Win XP disc and repair the installation.
Jan 31, 2010 | Acer Aspire 5050 Notebook
ACER 5050 NOTEBOOK CAMERA NOT FOUND WHAT DRIVER
You can get the drivers from here:
http://www.acerdriver.org/?gclid=CJiUzdTt5ZwCFVhB5godijRJHA
Might cost you a few dollars but will save you the agpravation.
Sep 10, 2009 | Acer Aspire 5050-3242 Notebook
Acer aspire 5050 keeps looping the acer screen and shuts down
If the hard drive tested out ok (?) then I would burn a copy of memtest (free just google it) boot from it and test the memory. I would suggest though that the issue is the hard drive or possibly motherboard
Jul 16, 2009 | Acer Aspire 5050-3242 Notebook
Can't Get In My Computer
Do a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
Or an XP repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 11, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Acer 5050
by default acer 5050 have 3 partitions
1. OS partition (C)
2. Data (D)
3. Recovery partition (hidden).
If you deleted recovery parition, you can't recover your C parition using Alt+F10. Your only option is recovery from cd/DVD recovery that you created. if you didn't create the cd/dvd, you can call acer support to buy the recovery dvd.
Mar 16, 2008 | Acer Aspire 5050 Notebook
Won't boot
You need recovery Disc Or Windows Vista disc. Else you need Windows Xp With sata driver in It. Please try to find out from your friends Or from Acer Service center may be they will Help u.
Mar 12, 2008 | HP Pavilion dv6000z Notebook
Acer Aspire 5050-3242 Notebook Logo
398 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
