Question about iRiver N10 / iFP-1180 (128 MB) MP3 Player
My iriver got dropped and now it turns on very slow
Normally, to turn it on I had to press play once , and know I have to leave it pressed to turn it on and it turns on very slowly and same to reproduce a song and plays at an incredible slow speed and it doesn´t go to the menu!
  • 8 Answers
SOURCE: iriver H10 20Gb Jammed
Hi StevieB Try following.1/Prepare a handy tool (straightened paper clip) to insert into "reset" hole atop of H10 2/gently insert tool into reset hole and feel a click 3/ turn on H10 if this works great 4/if H10 continues to jam lock up then it may require reloading firmware sounds complicated but easy steps available chk iRiver support website
Posted on Apr 22, 2007
SOURCE: New Music files copied to my iriver will either not play or partially play
Backup the h340 to your pc, format the h340 hdd and reload it, refresh database.
Posted on Nov 10, 2007
SOURCE: iriver h10
During instaling new Firmware there is option for FORMAT disk, thus all data will be deleted and disk reformated
and then also can try to chech errors on disk by standart windows properties
Posted on Jan 31, 2008
SOURCE: iriver s10 problem
Reset and it will work
Posted on Sep 17, 2008
  • 1285 Answers
SOURCE: New hard drive has trouble downloading songs & won't play
hi there, open iriver again and take new drive out (reinstall hard drive, just an adjustment process). close it up and try to download / play a file.
now if this process dont work, save iriver software to pc and format the hard drive (this will erase the hard drive songs and all) reinstall the software from the your songs back to iriver and you should have a brand new Iriver ihp-140............if heplful feel free to rate
Posted on May 30, 2009
  • 4 Answers
SOURCE: my iriver t7 starts on the same song when powered
try and erase all the songs and sync it again
Posted on Feb 28, 2010
0 characters
1 Points
My iRiver does not connect to my PC but shows the unit is charging
Press Play to make it connected.
You can also turn USB Charging off via a long press of the NAVI button to get to the menu then it's under control
Jan 21, 2015 | iRiver H340 MP3 Player
How to do voice recording
Turn on your iRiver device.
hold the center button in until you see the screen is at the FM, Recording, Browse or Settings. These are accessable by left and right directions.
Once you are at the Recording option, quick tap the center button. And then press the record button on the top of the device. The Stop/Play, A-B buttons are also on top next to the record button.
You may need to be sure the headphones are disconnected.
hope this info is useful.
Feb 07, 2013 | iRiver T10 MP3 Player
Just bought an iriver S100 GB mp3 player but computer doesn't recognise it. I've tried using device manager and usb settings but still no joy.
Go to settings, Advanced, Click Rebuild Database. Also make sure you are uploading songs through iRiver Plus 4
Sep 23, 2010 | iRiver X20 MP3 Player
How do I turn the shuffle feature off?
On the iRiver Clix
  1. while playing music press and hold [Right] for displaying the additional features.
  2. select Play Mode with up / down for going into the playing mode
  3. press right for entering the Play Mode menu
  4. change Play Mode with up / down
The Smart Key on the right side of the player can also be assigned as
Play Mode switch for shuffle on / off. The Smart Key can be set in the Settings of the player.
for going into settings press right on the display
for selecting an item in settings, e.g. Smart Key, use the screen's edges up / down
press right in the screen, when Smart Key selected, for going into changing Smart Key function
press up / down for changing the Smart Key function
repeatedly press left in the screen for going back to the top menu
Jan 15, 2010 | iRiver Clix Digital Media Player
My element mp3 player is playing music so fast how do i slow it down
Press the << button once or twice until music plays normally. If it plays too slow, press >> button.
Nov 28, 2009 | Element Electronics Zr-Element Digital...
Shuffle mode
Cut and modified from Douglas E. Levy at Amazon forum:
When you're in the Now Playing screen press and hold the Play/Pause button (right edge of screen). At the top of the slide-in menu you'll see Play Mode. Click Pause button again and scroll to "Normal" and choose it.
Jul 03, 2009 | iRiver MP3 & Digital Media Players
Iriver s10 problem
there is a 'reset hole' next to the power on switch - you need a pin to push into the reset hole
I do not use the software that comes with the S10 - it always wants to go on to the internet and re download itself. If I want to copy music over I use windows explorer and copy MP3s into the music folder
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Jun 07, 2008 | iRiver S10 2 GB MP3 Player
E10 iriver freezes and is excessively slow
It may not work, but.
Find the reset hole in the side of the E10 and perform a reset (you shove the end of a paper clip in the hole)
I have fixed my wife's and my daughter's by this method a couple of times!
Nov 22, 2007 | iRiver E10 Digital Media Player
Iriver H10 20Gb Jammed
Mar 28, 2007 | iRiver H10 MP3 Player
Player wont switch on
I have the same problem in that nothing happens when I press down the play button on the base unit. However, when I press play on the remote the unit turns on. Not sure if this solution applies to your problem...
Aug 03, 2006 | iRiver iHP-120 MP3 Player
iRiver N10 / iFP-1180 (128 MB) MP3 Player Logo
20 people viewed this question
Top iRiver MP3 & Digital Media Players Experts
Steven Wander
Steven Wander
Are you an iRiver MP3 and Digital Media Player Expert? Answer questions, earn points and help others
