Shut down, no pic/no sound just the red timer light
Samsung HCN653W rear projection tv, went black while watching it and has the steady burning redtimer light, have tried unplugging everything and plugging back in and still nothing but the steady red timer light, what do i need for this to fix it?
  • 2 more comments
  • may55656 May 26, 2009
    How do I replace it and where do i get it? Thanks
    Need more info than what you gave me, where is it located in the tv and where do i get one and can i do just the bulb? It is a 65" tv. Thanks
  • may55656 May 27, 2009
    Do you know of a diagram because i don't see a access door with 4 screws or a small red sticker on the left side of the tv.
  • may55656 Jun 02, 2009
    So maybe you should look your stuff up before you give the bum steer, cause i took it apart looking for that door. duh. so why are you telling people stuff you don't even know???????????
  • 147 Answers
You need to replace the lamp. you can do this yourself.
Posted on May 26, 2009
  • TONY BIGNELL May 27, 2009
    There is an access door on the back with 4 screws. Then the lamp is held in by 2 screws. You'll have to check around locally for where you can get one or buy one off the internet. There should be a small red sticker on the left side of the Tv with the lamp code on it.
    sorry, I gave you a bum steer. This model does not use a lamp. You should have a qualified technician look at it.
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
Samsung HCN653W DLP TV will not come on.
how sthe bulb on it is it new been chaged can u unplug unit for wile plug back in how many flasshes can u count usally flasshes meen a serv code
Jan 24, 2008 | Samsung HCN653W 65" Rear Projection...
I have no sound and no pic have talked to people on internet may be bad ic's dont know. I have unpluged ic's board and get a static sound and a tone when i turn it off and on and the timer light...
After the timer light blinks for a while say a few minutes do any other LEDs start blinking along with it? Please provide this info so that I can help you with your problem.
Sai.
Jul 17, 2011 | Samsung HCN653W 65" Rear Projection...
Was watching tv there was a flash of light picture went out and no sound either red led power light comes on but thats it no pic no sound
Replace Both of your STK ICs nd 6 resisitors they are big black ICs will have part # on them STK392-110s .
RK42-RK 46-RK50-RK54-RK58-RK62
3.3) -( 1.8) -(2.7 ) (1.5) (3.9)- ( 2.2ohms)
Sep 25, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black screen and red timer light is on
It may be the problem of the Dish connection or stablizer. Remove the stablizer and connect the Tv direct to switch board and re connect the dish connection. Then switch on the TV it will work.
Nov 04, 2008 | Samsung HCM4215W 42" Rear Projection...
Tv will not come on
Hello brexpress,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Jun 13, 2008 | Samsung HCN653W 65" Rear Projection...
No Picture - Sound
I just had this problem fixed. In my case, it was because the insulation on the CRTs was cracked, and when it would warm up, the shielding would separate and would let 5000 volts arc across the main board. This, obviously, damaged the board. The tech didn't catch the arcing right away, so they replaced the main board twice before they used a high-temp RTV to patch the insulation.
The power-cycling was a result of the damaged board.
The point of this story is that the broken part may be a symptom of the real problem.
I hope this helps someone!
May 29, 2008 | Samsung HCN653W 65" Rear Projection...
Lost picture and sound On Samsung HCN653W Rear Projection TV
If the picture is reduced in size all the way around, then you are looking at a power supply issue. That would also explain it shutting down.
Nov 30, 2007 | Samsung HCN653W 65" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
