Question about Home Security
Popping fuses when powering up this unit
I have installed 3 level one cameras # fcs-1040 with d-link dwl-p200 poe adapter. One of the cameras pops the fuse when the d-link is is plugged to the camera. The other units work. Can you help.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Is the wiring stapled anywhere?
Posted on Aug 08, 2009
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
I have 3 Dlink access points DWL3200AP for which I need D/C adapters. (connectors) power surges have ruined the conenctors event hough the access points are working well. Ihave been to the DLINK webpage...
You can use adapter of DWL-2700Ap and use POE to power your access point. It will work fine. If that is not available, you can mail us. we can arrange the adapter in India. You can contact us at cctplgoa@eth.net. Good Luck Anirban
Mar 09, 2010 | D-Link AirPremier DWL-3200AP 802.11g/b...
Can't access D-link DI-614+ as admin
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Mar 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
Cannot connect one d-link dwl-7700ap to another d-link dwl-7700ap
You have to add the MAC address from one unit into the other and Vice versa. Set them up in the repeater mode.
The product manual is on this link, under the Support Resources:
http://www.dlink.com/products/?pid=292
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 27, 2008 | D-Link DWL-7700AP AirPremier Wireless AG...
Wireless cardbus adapter
To be able to download the appropriate driver, you need to specify the revision of the DWL-G650 (Rev A, Rev B or Rev C. Rev B has 5 sub revisions while C has two).
Pls go here and enter "DWL" thereafter "G650" and then click on the revision number of your unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 02, 2008 | D-Link Air DWL 650 802.11b Wireless...
Failure to install D-link Air DWL-122 on Windows XP
I think the D-Link Adapter is a piece of ****. I have tried 3com and netgear and they all work well. Try setting Static Address instead of dynamic. Saying that - I didn't power down either as the instruction manual is totally useless.
Apr 30, 2008 | D-Link Air DWL-122 802.11b Wireless...
Home Security Logo
106 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
