Question about Garden
Absolutely no water pressure on Husky 2600 psi w/ HOnda motor
Used only occasionally, pressure washer has absolutely NO water pressure
Hook up water hose dose not pump water?
Posted on Oct 16, 2010
Can I USE SAE 30 NON DETERGENT OIL IN MY HUSKY 2600 PSI PREASURE WASHER.
Gasoline-powered pressure washers use an SAE 30W motor oil (10W-30) in the engine. Always consult the engine manual for specific instructions and be careful to put the correct oil in the correct place.
Pressure Washers Buyer Guide
Aug 03, 2015 | Psi Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
I have a Husky power washer 2600 psi starts & runs until it seems to build Pressure and will not spray then motor boggs to a stall
Some models have a tiny orifice in the adjustable spray head.(if equipped) Which can become clogged by debris or calcium buildup. Water should flow through even when unit is off and sprayer handle(on/off) is operated if there is no water then you definitely have a clog.
Oct 31, 2013 | Garden
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Jul 10, 2010 | Garden
Absolutely no water pressure on my husky 2600 psi, I use sparingly..........
Hello there:
if you have already cleaned the filter for the hose than the regulating valve also has a filter assy with it too may want to check it also the nozzel will clog easily when sitting for a while. so you may want to check that out. ok
best regards michael
Aug 29, 2009 | Honda Garden
I hAVE A 2600 PSI HUSKY PRESSURE WASHER, AND I HAVE NO PRESSURE GOING TO THE NOZZEL. i HAVE CHECKED EVERYTHING AND EVERYTHING IS ATTACHED.
remove the pressure hose and turn your water supply on and water should flow thru the pump on out where the pressure hose is. If not you have a blockage in the pump.
Jun 07, 2009 | Garden
Pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Apr 09, 2009 | House Brand Garden
Garden Logo
4,177 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
