Question about IBM Computers & Internet
Windows cannot detect a sound driver for my onboard sound
There appears to be no sound driver installed
    Problem Solver:
  • 9 Answers
If you have installed the driver, and still no sound, you should check if the soundcard isn´t disabled in BIOS (most of bios-es start when you hit Delete while restart- please don´t play loose with those things, just look after what you need and give the ENABLED value, then save and restart)
Posted on May 26, 2009
My hard drive crashed and burned so I bought a new installed it with windows 7. Now I have no sound or device installed. I've tried to detect it but no good. What do I need to do to correct this...
You might need to do some research. You will need to know who your sound card manufacture is and download the driver disc for it. If this is an onboard sound with the motherboard, you might be able to find who the manufacture is by looking for your motherboard specs. In windows was it able to detect the hardware as "unknown" in the device management in your control panel. Sometimes going to the windows7 website, it may have some update on the sound drivers.
Jan 27, 2011 | Computers & Internet
The sound drivers won't install and no sound device is detected by the system.
Check in the BIOS if the onboard audio is detected and activated. If it is then power cycle it: disable, reboot, reboot, enable it - that should force Windows redetect it.
Jun 10, 2010 | DFI LANPARTY DK 790FX-M2RS Motherboard
Onboard sound card not working (ASUS A7S333). I had a pci sound card and removed it to go back to the onboard sound.
You have to refresh your system by deleting the old sound card driver in the control panel or add/remove programs . Then restart the pc to detect the old onboard sound card driver. Then install the onboard sound card driver using the supported motherboard cd driver.
Feb 12, 2010 | ASUS A7S333 Motherboard
When I plug my monitor into my video card i get "no input signal" yet if i plug it into the onboard slot it works.could my PCI-E slot be bad?
Did you add a video card? If you have an AGP slot, it is best to put the video card in it. If so you need to go into the Device manager. Remove, disable or uninstall the onboard VGA driver. Go ahead and remove the PCI video card driver as well. Power down PC. Make sure monitor is hooked up to the Video Card, not onboard VGA. Power on PC. When Windows loads, it should detect the VGA card first, but if it detects the onboard first, ignore and don't setup onboard first. When Windows detects the card, load the necessary drivers when prompted. There is no need to reinstall the onboard driver for the video unless you wish to hook up two monitors.
Nov 08, 2009 | HP w1907 LCD Monitor
I am not able to install sound driver. when i check in bios settings there is no sound option for disable and enable.
check under onboard chip. but if you motherboard doesn't have sound device most likely there is no option on it, if you plug a soundcard into your motherboard it will detect itself as your windows starts. there install the driver.
Sep 29, 2009 | Intel D865GBF Motherboard
Sound card drivers can not installed
Your card isn't supported by Creative anymore, it is too old. As such, you would have better results by using a newer card. But the drivers are located here - http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=207&prodID=4851&prodName=Vibra%20128&subCatName=Others&CatName=Sound+Blaster
Dec 28, 2008 | ASUS P4VP-MX Motherboard
My computer cannot detect my multimedia audio controller
Download Microsoft UAA drivers for your O/S
Uninstall your sound drivers through device manager. then install the UAA drivers and REBOOT
then install your sound drivers
The only thing I can think of was you did not reboot after installing UAA drivers
Nov 10, 2008 | Intel D845GVSR Motherboard
Sound card drivers
did you install sound card drivers also motherboard drivers if not your computer will not operate at its best
Jul 16, 2008 | Intel For All Celeron D&Pentium 4 (Socket...
Speaker not working
CHECK IF THE SOUND DRIVER HAS INSTALLED PROPERLY OR THE ONBOARD SOUNDCARD HAS BEEN DETECTED OR NOT.IF NOT DETECTED TRY THIS: 1.INSTALL XP AGAIN. 2.TRY REMOVING ALL SOUND RELATED APPLICATIONS AND RESTART THE MACHINE SEVERAL TIMES.
Jun 01, 2008 | Audio Players & Recorders
NO SOUND
Hi, try reloading your audio drivers first. If this is on board sound the drivers will be on the disk supplied with the system.
XP will also detect and run most onboard sound. If you have nl luck with the drivers then install a PCIE sound card, they are inexpensive and simple to install.
Regards mistyman
Oct 10, 2007 | Leadtek WinFast TV2000 XP Expert...
Computers & Internet Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
