Question about General Electric WBVH5100HWW Front Load Washer
GE wbvh5100 Door lock will not ''unlock'' Door is stuck open
This happened once before, but I don't remember how I fixed it. I ran a load that didn't finish right (it was stuck on one minute remaining and humming). I pressed the power button and the door disengaged. (or so I thought). Now, I set it up to run another load and the door won't close. On inspection the lock mechanisim is in the locked mode. I can get a cycle to run if I hold the door shut, and it makes the locking/unlocking noise, but the lock does not move. I verified that my discharge filter is clean. There was some water under the washer, but I'm not sure if that was from me testing or cleaning the discharge filter.
  • gamma1148 May 26, 2009
    Yea I tried that, I get an electrical sound like it's trying to unlock the door, that repeats like 5 times then it stops. No joy. I even ran through a wash cycle with the door propped shut using a chair. :-)
I am having the same problem right now. I couldn't get anything to work, so I unplugged the machine for a minute or two, and then plugged it back in. The door lock made a funny sound, but it's working again. Good luck.
Posted on May 26, 2009
GFWH1200DWW GE front load washer won't unlock red lock showing
From an article I found online:
See if manually opening the door will reset everything. Unplug the washer and remove the lower front panel like you're going to clean out the drain catch. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
Now once you have the door open, plug the washer back in and see if you can start another cycle.
Mar 06, 2016 | GE Washing Machines
Doors not opening even if they are unlocked
My 2009 Sebring does the same thing occasionally but only the drivers door gets stuck (dead locked - even though the locks appear to pop up).
The solution I have found once this happens is:
1) The car needs to be driven (crawl in thru the passenger door) -even just a short distance
2) Engine shut off & doors locked with remote (after you've exited from the passenger door of course)
3) Leave turned off for 10 minutes
4) Doors will now open when unlocked with the remote
Mar 14, 2014 | 2007 Chrysler Sebring Sedan
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
Our Samsung J1455AV door won't open, just over a year old. Have cleaned the filter, re-run a cycle, turned off at wall. Help!
Hi
Thanks for using FixYa. To start with if the door lock is stuck and wont unlock then you can pry it to open, and just don’t try too hard. The issue can be with the door latch that is stuck, to unlock it you can stick a flat screw driver behind the door latch and then lever it to open so that you don’t have to pry it to open. Once it’s done, please make sure to replace the door latch assembly to avoid any further issues. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 12, 2010 | Washing Machines
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After a load it makes a sound and as if the door
your lock could be bad, but when it unlocks it buzzes as if already unlocked? Is the door actully unlocked during the cycle but display reports locked? this would be a bad switch within the lock asm
Jul 14, 2009 | GE Energy Star WCVH6260F Front Load Washer
The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We werent self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try...
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Oct 14, 2008 | Frigidaire Kitchen Ranges
Ge front load wcvh6600.
our door kept sayin "door locked". a technician came out to see it and said it was the door lock but that he had temporarily fixed the problem. he said to call if it happened again and would have to order new door lock which runs about $160. after six washes it said door locked again. he came out agian and within 5 minutes of diagnosis said it need a new door lock. i was furious bc i had already payed him and found an new door lock on Ebay for about $70. Got the manual off the internet and had my hubby replace door lock. not very hard except when he replaced it it still said dook locked. after several hours i told him to unscrew the bottom panel because i had seen tec do the same. to our amazement, one of the wires had come loose and needed to be plugged back in. amazingly it started working perfectly. then , i put a big load of towels in and it started shaking badly again and the same problem reoccured. DOOR LOCKED. so we took the bottom panel off and the wire had com loose again. we stuck it back in and wah-la... it worked again. this has happened about 4 times now and everytime we just open them bottome panel and replace wire. i believe we never even needed the new door lock to begin with? we havent checked putting the old door lock back in but i bet it would work because it looked like nothing was wrong with it when we took it out. I hope this helps before you spend an extra $200 or so like we did for a loose wire. we have now just left the front bottom panel off and when it happens, i just bend down and tighten. Hope this helps.
Apr 26, 2008 | GE WCVH6260F Front Load Washer
"door lock" light stays on and oven won't work
On mine, I was able to take of the face plate and unscrew the metal locking arm from the motor. Once i wiggled the locking arm away from the locked position I was able to open the door. Once i opened the door, the little motor which controls the locking arm automatically rotated to the unlocked position and cleared teh "locked door" message on the control panel.
Apr 27, 2007 | GE JTP15 Electric Single Oven
General Electric WBVH5100HWW Front Load Washer Logo
351 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
