Question about Refrigerators
Kenmore refrigerator water dispenser
I need to replace the valve assembly on my Kenmore refrigerator (Sears model number 795.75192401).  I have the part but I can't figure out how to get the tubing to uncouple from the inlet nor from the outlet to the water reservoir without breaking the plastic.  What's the "trick" to getting them apart without breaking them?
  • 3 more comments
  • waterless Oct 21, 2007
    Thanks for the solution to the tubing problem.  It worked like a charm.  Can you tell I skipped out on shop class?  Anyway, I still don't have any water through the door but at least now I can hear the pump cycling.  I just have to figure out what is stopping the water from making it to the outlet.  I know I have water to the system because the ice maker is working fine.  The problem must be somewhere in between the two.  Back to the drawing board.
  • waterless Oct 28, 2007
    I still don't know what caused this problem because I still don't have water flowing.  I do know that my valve assembly (behind the door, inside the fridge) gave out.  Replacing it fixed the valve problem (I can hear it opening when I depress the switch) but I'm not getting any water through.  It appears that the first problem has led to another problem.  I'm working backwards from the valve to see what else could be the problem.  I'll let you know if I find anything new.
  • Scott Magill Apr 13, 2008
    have water to ice maker but no water to water dispencer
  • zzqqq1 Dec 07, 2008
    i have the Sears Kenmore model 795.75549401, which may be similar. The water va\lve assemby is leaking, so I intend to replace this part, but the first evidence of the problem was a failure at the water dispensor (not the icemaker). Interested in what you find out before i spend the $100 on the water valve assemby (especially if that is not the real problem)..
  • billandlorie Jan 08, 2009
    I cannot make the new valve assembly stop leaking. All new parts and still leaking. New valve and tank. So frustrated. What am I missing?
  • 473 Answers
Where the tube goes into the vavle there should be a compression fitting if I understand your description.  It looks like a little ring may be blue or red.  Push in on that fitting while pulling the hose out at the same time.  To reinstall just push the tube into the fitting all the way until you feel it seat.  Let me know if this helps or you have a different set up.
Posted on Oct 20, 2007
After changing the water filter, the ice maker is not working. The water dispenser is working properly.
You may need to replace the dual water control valve due to only the water dispenser side of the water control valve being the only side that works. What is the model number of your Kenmore refrigerator? Kenmore model numbers look like this=> 321.235689 as an example. An example of the water control valve if your model number was 321.235689 is part number=> 12001414 Water Inlet Valve
Don't use this example as the correct part. Look around the fresh food section door frame for your correct model number, Thanks
Sea Breeze
Testing the Water Control Valve
Mar 31, 2013 | Kenmore Elite Side By Side Refrigerator -...
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Water will not flow. It is a kenmore cold spot
Most likely the dual water control valve is not opening to allow the water to the dispenser if that is your meaning. Now if you mean water for both dispenser and ice maker then that would change everything. See if you can locate the model number that Sears puts on the door frame near floor. The fresh food section door at base and the number will look like this example 312.256489 With that number I can see everything your side by side came with and tell you the parts and locations. You also can have someone test voltage going to the water control valves while someone presses the dispense water switch. And with a voltage meter set to OHM's test the coils on the dual water control valves for resistance and if one has a very different number that can tell you. So we have several things to look for, water supply, dual water control, (if one works and other will not) and model number, Let me know what you find, Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dripping out of water dispenser tube
SOUND LIKE YOU HAVE A BAD INTAKE VALVE. IF THE WATER DRIPS ALL THE TIME.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | Kenmore Refrigerators
My water dispenser does not work. I unscrewed the hose at the bottom of the door and there is water pressure there. Where should I be looking for the problem?
If pressure there it could mean anything may be possible. I need the Sears Model Number. If the water valve on rear of refrigerator does not open then water will not exit the dispenser. Sometimes water is frozen in the dispenser water container located inside the fresh food. Sears Numbers Look Like this (231.564897) for example
compartment. And sometimes it is the dispenser controls. I will need your Kenmore Model Number to tell you the part you need and to help you better. Thank You, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Jul 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Doble door kenmore new fiter water not working
While working withe filter assembly it is possible that you unplugged the dispenser electrical connection. I will need the Sears number for example 213.258978 to assist you better. Let me know
May 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Condensation on the outside of the ice/water dispenser on freezer side.
Turn the water supply off to the back of refrigerator and take the line feeding the supply to the water control valves off and then put the line into a pan to purge any trash that may have collected before entering control valve. It is very possible that a piece of rust or a piece of plastic is holding the control valve open slightly. The continuous dripping of the chilled water is what I suspect is causing the condensate. On bottom of the refrigerator Sears uses a number like this example. You may find the number behind the cold food section door near floor. I will need that to help you better. Example 215.22897
Sears always gives their models a different number than the same models that GE, Whirlpool, Westinghouse and on and on. When you are able to see if the valve is stuck and need to clean or replace it we will need your model like in the example to find the correct part, Let me know, Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Kenmore side by side refridgerator w/water and ice in door
If there is a lot of water dripping and I guess there is since you had to turn the water off, you need to replace the dual solenoid valve to cure your problem. You did not post your model number so it is not possible for me to say if you have more than one valve assembly in your refrigerator. If you have 2 separate valve assemblies you will need to disconnect the lines one at a time to locate the correct valve to replace. I hope this helped you.
supertechks
Please don't forget to rate me
Jan 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
1,345 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
