thanks we have it apart and it is the belt and we will be putting it on tomarrow it is a maytag pyet344ayw thanks we have it apart and it is the belt and we will be putting it on tomarrow it is a maytag pyet344ayw
You can't post conmments that contain an email address.
they are not hard to put on, but can be tricky if you have never seen a dryer belt set up. before buying a new belt, open the door and try to turn the drum by hand, if there is little or no resistance it is definatly the belt. or better yet pull the front panel off to visually see if the belt is broken or just has come undone. instructions for most dryers. if lint trap is ontop - remove remove 2 screws at lint trap if lint trap in door use flat blade screwdriver or putty knife to locate and push in clips that hold the top in to open the lid. like a hood of a car wow.. this will be long, much easier if i get the model top mount control or front, same as where the lint trap is located
? 1:26 https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
is it hard to put on
