Question about JVC KD-HDR1 CD Player
Ipod touch my ipod touch wont play as well. is there any way to fix this
Updated my ipod software and now it wont play on my home theatre system
This is always tricky with 1st generation iPod touches. After a while they can't handle the new software anymore and some functions won't work anymore. Maybe try to downgrade the software. Otherwise you should probably get a new iPod.
Aug 21, 2012 | Samsung Home Theater: HT-C5500 MULTI...
I was playing a game and all of a sudden the screen went white and wont do anything,not even make a noise.how can i fix it?
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
Apr 07, 2010 | Apple iPod touch
My ipod wont play on my AVIC F910BT
I don't know if you fixed it already this iPod sound trouble, but I got ot also and found how to fix this trouble.
In fact there's a setup to do and mention in the User Manual (page 89 on the english one) the AV1 config should be selected as iPod
Using an iPod (iPod) Starting procedure
Connect your iPod.
No sound or video output if iPod is selected
as AV source, check the setting in “AV1
Input” on the “AV System Settings” menu.
Dec 25, 2009 | Pioneer GPS
Ipod touch music wont play, built in speaker works fine
Restart your ipod by holding the home and power button at the same time, this will restart it and should fix it.
Aug 12, 2009 | Apple iPod touch
Wont play out of docking speakers
Hi
My iPod does the same it does not play out certain speakers.
Take back the speakers.
Take back the ipod.
Go to:http://www.apple.com/support/
Tom
Jul 05, 2009 | Apple iPod touch
Doesnt turn on.
This same thing happened to me. I was playing fantastic contraption and my ipod screen just went black and wouldnt turn back on. When I plugged it in to a charger, it made that charging noise, but wouldnt turn on. SOLUTION: try holding in the sleep/wake(power) button, and the home button at the same time for about 15 seconds or until you see the white apple logo. That worked for me, hope you get it fixed.
Flaming Llama
Jul 04, 2009 | Apple iPod touch Second Gen (8 GB,...
Wont play through my bose system anymore
the apple ipod are very delicate and it seems that docks are very harsh on the internal workings IE: motherboard of the ipod. it not just the touch, it's all ipods.
My suggestion is to check the headphone jack and if you get sound, don;t play your ipod on the dock at all. Your dock has probably done some damage to the audio circuit on the board.
If you get sound through the headphone jack save your ipods life and just use it through the jack.
I have replaced numerous motherboards on ipods played on docks. they just don;t handle the charging and playing very well whether it's heat or just the wrong voltage I am not sure.
But my first question to a customer is have you played it on a dock.
I would stay away from the dock
Apr 30, 2009 | Apple iPod touch
Ipod cuts out when played through speaker system
i have somewhat of a similar problem with my ipod Touch and my JBL docking station alarm clock thingy. It may just be that the ipod is not compatible on some of the levels that the Igroove is. With my docking station, it wont charge my ipod touch itll only play music
Apr 11, 2009 | Apple iPod nano
My iPod wont play music
restore itusing itunes/
also if that is not working try to upgrade it firmware cuz those funny acts occurs when the firmware is corrupted or damaged through some serious use!!
Mar 31, 2009 | Apple iPod touch
My Jensen ipod docking system wont charge my i touch
The older ipods charge using 12v, the newer ones (including the Touch 2nd gen) use 5v. So a lot of docks that will charge a nano will not charge a new Touch. If a dock says it will work with the iPhone then it will work with the newer iPod Touch (2nd gen).
If you have an old dock and want to charge a new Touch (sounds like the case here) then you can get an adapter. Scosche makes one just for this.
Dec 26, 2008 | Audiovox JENSEN IPOD DIGITAL DOCKING...
JVC KD-HDR1 CD Player Logo
96 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
