Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
DS-603 lights keep blinking, won't stay turned on.
Hi
I have a single drawer Fisher and Paykel dishdrawer that has suddenly stopped working after never having a problem for 2 years. The red lights on the inside top just blink on for a second and the unit makes a clicking noise, like a safety switch is being tripped. At the same time the LCD display shows all its data for a second.
If I turn the unit on with the power button it stays on for about 3 seconds before it trips again.
The unit keeps going through this cycle of blinking, then 5 seconds, then blinking, etc, constantly while the power is on.
WIll I need to get a tech out? Now and again I see little cockroaches around. Could these have shorted it out, and if so will it be expensive?
Cheers!
Hi. I am unable to help you fix your problem, however I have just had this problem with my dishwasher exactly the same model. I was wondering if you have fixed this problem yet and if you have how.
Posted on Jun 28, 2009
My drawer on my fisher & paykel drawer sticks
I found a ball bearing stuck in one of the draw runners ?
http://www.scribd.com/doc/6462163/DD601V2-Manual see if this link still works
Sep 29, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishdrawer f2 error
This is linked to a rotor problem. Check this video and clean the cavity. If no difference then need to replace the rotor.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Feb 16, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishdrawer lid will not stay locked
Assuming this is happens with only one drawer - most likely controller is recongising some sensor problems. If the water inlet is faulty then it is waiting for water to get in. Alternatively, the sensor that tells it the drawer is closed suddenly misbehaves and confuses the controller which stops the cycle.
Feb 13, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishdrawer door comes ajar
It is also likely the drawer has come off the gliding rail at the right.
You will have to pull the drawer out from the housing and check. Not sure if you have a standalone unit or integrated with the kitchen cupboard. The instructions to pull drawer out are available in the installation manual. Select the correct model from this site .
http://www.fisherpaykel.com/au/support/user-manuals/
Dec 08, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Water will not empty and beeping will not stop on Fisher & Paykel DD6051
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Sep 14, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Aug 19, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
Have the Fisher & Paykel single drawer dishwasher ds 603 and put it on a normal cycle last night. It started as per normal and sometime during its cycle it stopped and the drawer now seems locked. ...
It is very likely the thermal fuse has blown or the power supply board has had it. Either way the power to the controller and the drawer lid seal motors is cut off. This is why the drawer is in locked state as the motors have seized.
You have no choice but to force open the drawer to get access to the affected parts. Make sure the mains power to dishwasher is turned off as the base will be live.
Replacing the power board is easy but if the thermal fuse is blown then you are up for a large cost as it is integral in the heating element.
Refer this document for details of parts and location. Heater is item 17 on page 18 and powerboard is item 15 on page 13. (the document is for double drawer model but it just doubles up on parts)
You can get a rough idea of the parts cost from this site. Depends where you live.
Hope you are able to get it fixed.
Jan 27, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
Dishwasher won't *******
Turn mains power off and on after a little time.
Do you get any fault code on the display if you have LCD or if integrated, which lights are on on the drawer door?
Jun 05, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Sep 08, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
381 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
