Question about Car Audio & Video
My cd will not play or eject the cd case - Car Audio & Video
    Problem Solver:
  • 13 Answers
This is a common problem, and an indication that your cd player is reaching the end of its life. Unfortunately the only solution is to buy a new one. As for getting your CD back, you may have to disassemble the head unit
Posted on Jun 06, 2009
I have a 2004 Mazda 3 w/ a single disc CD player...which has not been working for several months. There is a cd in the player but nothing happens when I press the eject button nor the CD button; won't...
Possible that the cd disc has jammed due to a change in the disc- warming can bend some cd's, also if the cd is struck inside as the loading mechanism is struck. In both cases the set must be pulled out if there is no hope with trying to retrieve the cd softly assisting while ejecting. If you do not hear any noise while the eject is pressed then the loading drive is faulty , you need to remove the cd , open to check, If this is mechanical then you can softly push the cd out, if not the electonic section needs a check.
May 03, 2011 | 2004 Mazda 3
Cd player doesn't play or ejects cds.it shows like there's cds inside but nothing comes out when the eject button is pushed.it displays"player error".what could be the problem?
The CD is probably not in the carousel the way it should be and cannot play and also has the door jammed so it can't eject. Sometimes this can be fixed by taking a thin object like a credit card and sliding in between the top of the door and the case. If you can move the CD just a little, you may be able to get it to eject.
Jan 28, 2011 | 2002 Buick Rendezvous
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Trouble Ejecting CD. CD not playing
One thing have you tried to pull the CD out?
Dec 09, 2009 | 2001 Dodge Caravan
Can't get a CD to eject on my '05 RAM 1500 RBK Radio
We have tried several of the solutions offered. (i.e. holding eject button down several seconds and then pressing again; inserting another CD into slot 1.5 " and using eject button at same time; pulling the fuse on the radio and waiting 10 minutes w/o using key in ignition and then reinstalling fuse. NONE of these worked. There's a certain amount of satisfaction to "fixing" a problem on one's own, BUT nothing we read about and tried worked. Since we bought the 2005 RAM just last week, we're going to take the problem back to the Dealer to fix. THANKS.
Mar 23, 2009 | 2005 Dodge Ram 1500
My Dodge RAM Car CD will play OK, but won't eject.
If this a CD with a paper label, sometimes they will peel up on the edge and not allow the CD to eject or in same cases the CD is slightly warped.
One thing you might try is this..... Get a flash light and try and look into the CD slot when the radio is trying to eject. There is a black felt type material that you can lift up slightly and if you can see the disc edge trying to come out it may look like it is very slightly too high and getting caught. You can take a business card and try and slide it above the CD edge from the side and this will get the edge of the CD to come down and eject. This has worked many times for me anyway.
When i tried to eject my cd it didnt come out and i cant play cd's it reads error
I have a 2002 LS and sometimes get a problem trying to eject CDs. If your problem is the same as mine, then its relatively simple to get that CD out.
The little access panel on the head unit opens up but the CD does not eject, in my case there is a slight alignment issue and the CD gets stuck when trying to come out. The thing to do is to get a thin blade (a knife works), hit the eject button, pick a slot (any slot), and then slide the blade on the top edge of the CD that you see in the access port. Simply nudge it down and as long as the unit is trying to eject it will come out.
Good luck...
Feb 02, 2009 | 2000 Lincoln LS
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
GM factory installedTahoe CD player 2003 model
Try pressing and holding the Eject button for more than 10 seconds. If that does not work, you may have had some moisture infiltration that has messed up your circuits. You need to remove it from the dash carefully and open up the case to get your CD out. There is no button or trick to make it happen. Sorry , I wish I could help you more.
Nov 15, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
